BeginDoubleClick 事件 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 757| 评论: 0|原作者: admin|来自: AutoCAD
在用户双击图形中的对象后触发。
object.BeginDoubleClick(PickPoint)
类别: 文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是文档。
PickPoint
类型:变体(双打的三元素数组);输入到处理程序
双击的 3D WCS 坐标。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant)
    ' This example intercepts a drawing BeginDoubleClick event.
    ' This event is triggered when a drawing receives
    ' a double mouse click in its working area.
    ' To trigger this example event: Position the mouse over the working area of
    ' a drawing window and double-click the left mouse button
    ' Use the "PickPoint" variable to determine where on the drawing the user clicked
    MsgBox "A drawing has just been double-clicked at:" & vbCrLf & _
            PickPoint(0) & vbCrLf & _
            PickPoint(1) & vbCrLf & _
            PickPoint(2)
Not available
GMT+8, 2026-11-29 10:46
