XRefLayerVisibility 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 954| 评论: 0|原作者: admin|来自: AutoCAD
确定与外部参照相关的图层的可见性,并指定是否保存嵌套的外部参照路径更改。
object.XRefLayerVisibility
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:在当前图形中所做的与外部参照相关的图层更改优先。
  • False:存储在参照图形 (xref) 中的图层表优先。
此属性的初始值为 。True
当此属性设置为 时,图层设置将与当前图形的图层表一起保存,并在会话之间持续存在。嵌套的外部参照路径更改将与当前图形一起保存,并在会话之间持续存在。True
当此属性设置为 时,对当前图形中与外部参照相关的图层所做的更改仅在当前进程中有效,但不会与图形一起保存。当重新打开当前图形时,将从参考图形重新加载图层表,并且当前图形将反映这些设置。受影响的图层设置包括:开/关、冻结/解冻、颜色和线型。此设置还指定对嵌套外部参照路径所做的更改仅适用于当前进程,而不与图形一起保存。False
注意:此属性的值存储在 VISRETAIN 系统变量中。
Sub Example_XRefLayerVisibility()
    ' This example reads and modifies the preference value that controls
    ' the visibility of xref-dependent layers and specifies if nested xref
    ' path changes are saved.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.XRefLayerVisibility
    MsgBox "The XRefLayerVisibility preference is set to: " & originalValue
    ' Modify the XRefLayerVisibility preference by toggling the value
    ACADPref.XRefLayerVisibility = Not (ACADPref.XRefLayerVisibility)
    newValue = ACADPref.XRefLayerVisibility
    MsgBox "The XRefLayerVisibility preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.XRefLayerVisibility = originalValue
    MsgBox "The XRefLayerVisibility preference was reset back to: " & originalValue
(defun c:Example_XRefLayerVisibility()
    ;; This example reads and modifies the preference value that controls
    ;; the visibility of xref-dependent layers and specifies if nested xref
    ;; path changes are saved.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-XRefLayerVisibility preferences))
    (alert (strcat "The XRefLayerVisibility preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the XRefLayerVisibility preference by toggling the value
    (vla-put-XRefLayerVisibility preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The XRefLayerVisibility preference has been set to: " (if (= (vla-get-XRefLayerVisibility preferences) :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-XRefLayerVisibility preferences originalValue)
    (alert (strcat "The XRefLayerVisibility preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:49
