XRefEdit 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 851| 评论: 0|原作者: admin|来自: AutoCAD
确定当前图形在被其他用户引用时是否可以就地编辑。
object.XRefEdit
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:允许就地引用编辑。
  • False:不允许就地引用编辑。
此属性的初始值为 。True
注意:此属性的值存储在 XEDIT 系统变量中。
Sub Example_XRefEdit()
    ' This example reads and modifies the preference value that controls
    ' whether the current drawing can be edited in place when being
    ' referenced by another user.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.XRefEdit
    MsgBox "The XRefEdit preference is set to: " & originalValue
    ' Modify the XRefEdit preference by toggling the value
    ACADPref.XRefEdit = Not (ACADPref.XRefEdit)
    newValue = ACADPref.XRefEdit
    MsgBox "The XRefEdit preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.XRefEdit = originalValue
    MsgBox "The XRefEdit preference was reset back to: " & originalValue
(defun c:Example_XRefEdit()
    ;; This example reads and modifies the preference value that controls
    ;; whether the current drawing can be edited in place when being
    ;; referenced by another user.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-XRefEdit preferences))
    (alert (strcat "The XRefEdit preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the XRefEdit preference by toggling the value
    (vla-put-XRefEdit preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The XRefEdit preference has been set to: " (if (= (vla-get-XRefEdit preferences) :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-XRefEdit preferences originalValue)
    (alert (strcat "The XRefEdit preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:57
