Views 属性 (ActiveX)
获取文档的 Views 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Views()
' This example finds the current views collection and
' adds a new view to that collection.
Dim viewColl As AcadViews
Set viewColl = ThisDrawing.Views
' Create a view named "TEST" in the current drawing
Dim viewObj As AcadView
Set viewObj = viewColl.Add("TEST")
MsgBox "A new view called " & viewObj.name & " has been added to the views collection.", vbInformation, "Views Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Views()
;; This example finds the current views collection and
;; adds a new view to that collection.
(setq viewColl (vla-get-Views doc))
;; Create a view named "TEST" in the current drawing
(setq viewObj (vla-Add viewColl "TEST"))
(alert (strcat "A new view called " (vla-get-Name viewObj) " has been added to the views collection."))
GMT+8, 2026-11-29 23:45
