VerticalTextPosition 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 930| 评论: 0|原作者: admin|来自: AutoCAD
指定文本相对于尺寸线的垂直位置。
object.VerticalTextPosition
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、Leader
此属性应用于的对象。
只读:不
类型:枚举acDimVerticalJustification
  • acVertCentered:使扩展线之间的尺寸文本居中。
  • acAbove:将尺寸文本放在尺寸线上方,除非尺寸线不是水平的,并且延长线内的文本被强制为水平 (DIMTIH = 1)。从尺寸线到最低文本行的基线的距离是当前 DIMGAP 值。
  • acUnder:将尺寸文本放在尺寸线下方,除非尺寸线不是水平的,并且延长线内的文本被强制水平 (DIMTIH = 1)。从尺寸线到最低文本行的基线的距离是当前 DIMGAP 值。
  • acOutside:将尺寸文本放置在距离定义点最远的尺寸线的一侧。
  • acJIS:放置尺寸文本以符合日本工业标准 (JIS)。
此属性的初始值为 。acVertCentered
注意:此属性将覆盖给定尺寸、引线或公差对象的 DIMTAD 系统变量的值。
Sub Example_VerticalTextPosition()
    ' This example creates an aligned dimension in model space
    ' and cycles the dimension text through a couple of different
    ' vertical alignments
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 9: point2(1) = 5: point2(2) = 0
    ' Read and display current text position
    Select Case dimObj.VerticalTextPosition
        Case acVertCentered:    CurrentValue = "centered"
        Case acAbove:           CurrentValue = "above"
        Case acOutside:         CurrentValue = "outside"
        Case acJIS:             CurrentValue = "to Japanesee industrial standards"
    End Select
    MsgBox "The vertical position of the dimension is: " & CurrentValue
    ' Change the position of the dimension text to be above the extesnion lines
    dimObj.VerticalTextPosition = acAbove
    MsgBox "Dimension text is now aligned above extension lines"
    ' Change the position of the dimension text to be centered with the extension lines
    dimObj.VerticalTextPosition = acVertCentered
    MsgBox "Dimension text is now centered with the extension lines"
(defun c:Example_VerticalTextPosition()
    ;; This example creates an aligned dimension in model space
    ;; and cycles the dimension text through a couple of different
    ;; vertical alignments
    ;; Define the dimension
          point2 (vlax-3d-point 9 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current text position
    (setq CurrentValue (cond
                           ((= (vla-get-VerticalTextPosition dimObj) acVertCentered) "centered")
                           ((= (vla-get-VerticalTextPosition dimObj) acAbove) "above")
                           ((= (vla-get-VerticalTextPosition dimObj) acOutside) "outside")
                           ((= (vla-get-VerticalTextPosition dimObj) acJIS) "to Japanesee industrial standards")
    (alert (strcat "The vertical position of the dimension is: " CurrentValue))
    ;; Change the position of the dimension text to be above the extesnion lines
    (vla-put-VerticalTextPosition dimObj acAbove)
    (alert "Dimension text is now aligned above extension lines")
    ;; Change the position of the dimension text to be centered with the extension lines
    (vla-put-VerticalTextPosition dimObj acVertCentered)
    (alert "Dimension text is now centered with the extension lines")
GMT+8, 2026-11-29 10:46
