Verify 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 865| 评论: 0|原作者: admin|来自: AutoCAD
Verify 属性 (ActiveX)
指定是否为验证设置属性。
object.Verify
类型:属性
此属性应用于的对象。
只读:不
类型:布尔
  • True:该属性设置为验证。
  • False:未将该属性设置为验证。
设置为验证的属性会提示用户在插入块时验证属性值是否正确。
属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。AFLAGS 系统变量存储当前模式设置。可以使用 Mode 属性查询当前模式。
Sub Example_Verify()
    ' This example creates an attribute definition in model space.
    ' It then sets the definition to be verify, and queries the mode.
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    ' Define the attribute definition
    height = 1#
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "New_Tag"
    value = "New Value"
    ' Create the attribute definition object in model space
    Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ZoomAll
    ' Change the mode to be verify
    attributeObj.mode = acAttributeModeVerify
    attributeObj.Update
    ' Check to see if the attribute is set to verify
    MsgBox (IIf(attributeObj.Verify, "The attribute is set to verify", "The attribute is not set to verify"))
(defun c:Example_Verify()
    ;; This example creates an attribute definition in model space.
    ;; It then sets the definition to be verify, and queries the mode.
    ;; Define the attribute definition
    (setq insertionPoint (vlax-3d-point 5 5 0)
          attHeight 1
          attMode acAttributeModeVerify
          attPrompt "New Prompt"
          attTag "New_Tag"
          attValue "New Value")
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
    (vla-ZoomAll acadObj)
    ;; Change the mode to be verify
    (vla-put-Mode attributeObj acAttributeModeVerify)
    (vla-Update attributeObj)
    ;; Check to see if the attribute is set to verify
    (alert (if (= (vla-get-Verify attributeObj) :vlax-true) "The attribute is set to verify" "The attribute is not set to verify"))
GMT+8, 2026-11-21 00:57
