Value 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 963| 评论: 0|原作者: admin|来自: AutoCAD
Value 属性 (ActiveX)
指定属性的当前值或新创建的克隆对象的对象 ID。
object.Value
类型:DynamicBlockReferenceProperty、IDPair
此属性应用于的对象。
只读:否 (DynamicBlockReferenceProperty)、是 (IDPair)
类型:变体 (DynamicBlockReferenceProperty) Long_PTR (IDPair)
DynamicBlockReferenceProperty:属性的当前值。
IDPair:操作中新创建的克隆对象的对象 ID。CopyObjects
DynamicBlockReferenceProperty:如果无法设置指定的属性值,则不返回任何错误。例如,如果属性具有允许值列表或最小值-最大值范围,并且提供的值不在列表中或超出范围,则不会返回任何错误。
IDPair:使用该属性获取源对象的对象 ID。Key
Sub Example_Value()
    ' This example creates two Circle objects and uses the CopyObjects
    ' method to copy them. It then returns the object IDs
    ' of the new objects using the Value property and uses the
    ' object IDs to remove the new (target) objects
    Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
    Dim circleObj1Copy As AcadCircle, circleObj2Copy As AcadCircle
    Dim radius1 As Double, radius2 As Double
    Dim radius1Copy As Double, radius2Copy As Double
    Dim objCollection(0 To 1) As Object
    Dim retObjects As Variant
    Dim IDPairs As Variant
    Dim TargetObject As AcadObject
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius1 = 5#: radius2 = 7#
    radius1Copy = 1#: radius2Copy = 2#
    ' Add two circles to the drawing
    Set circleObj1 = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius1)
    Set circleObj2 = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius2)
    ' Copy objects
    ' First put the objects to be copied into a form compatible with CopyObjects
    Set objCollection(0) = circleObj1
    Set objCollection(1) = circleObj2
    ' Copy object and get back a collection of the new objects (copies)
    retObjects = ThisDrawing.CopyObjects(objCollection, , IDPairs)
    ' Get newly created object and apply new properties to the copies
    Set circleObj1Copy = retObjects(0)
    Set circleObj2Copy = retObjects(1)
    circleObj1Copy.radius = radius1Copy
    circleObj2Copy.radius = radius2Copy
    ' Display the object IDs of the source objects used for the copy
    MsgBox "The first target object ID is: " & IDPairs(0).Value & vbCrLf & _
           "The second target object ID is: " & IDPairs(1).Value
    ' This key can be used with objectIDtoObject to reference the source objects,
    ' which is useful if the user manually selected the source objects.
    ' Here we delete the source objects from the ID obtained
    Set TargetObject = ThisDrawing.ObjectIdToObject(IDPairs(0).Value)
    TargetObject.Delete
    Set TargetObject = ThisDrawing.ObjectIdToObject(IDPairs(1).Value)
    TargetObject.Delete
    MsgBox "The target objects have been deleted!", vbInformation
(defun c:Example_Value()
    ;; This example creates two Circle objects and uses the CopyObjects
    ;; method to copy them. It then returns the object IDs
    ;; of the new objects using the Value property and uses the
    ;; object IDs to remove the new (target) objects
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius1 5
          radius2 7
          radius1Copy 1
          radius2Copy 2)
    ;; Add two circles to the drawing
    (setq circleObj1 (vla-AddCircle modelSpace centerPoint radius1))
    (setq circleObj2 (vla-AddCircle modelSpace centerPoint radius2))
    (vla-ZoomAll acadObj)
    ;; Copy objects
    ;; First put the objects to be copied into a form compatible with CopyObjects
    (setq objCollection (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element objCollection 0 circleObj1)
    (vlax-safearray-put-element objCollection 1 circleObj2)
    ;; Copy object and get back a collection of the new objects (copies)
    (setq retObjects (vlax-variant-value (vla-CopyObjects doc objCollection nil 'IDPairs)))
    ;; Get newly created object and apply new properties to the copies
    (setq circleObj1Copy (vlax-safearray-get-element retObjects 0))
    (setq circleObj2Copy (vlax-safearray-get-element retObjects 1))
    (vla-put-Radius circleObj1Copy radius1Copy)
    (vla-put-Radius circleObj2Copy radius2Copy)
    ;; Display the object IDs of the source objects used for the copy
    (alert (strcat "The first target object ID is: " (itoa (vla-get-Value (vlax-safearray-get-element IDPairs 0)))
                   "\nThe second target object ID is: " (itoa (vla-get-Value (vlax-safearray-get-element IDPairs 1)))))
    ;; This key can be used with objectIDtoObject to reference the source objects,
    ;; which is useful if the user manually selected the source objects.
    ;; Here we delete the source objects from the ID obtained
    (setq TargetObject (vla-ObjectIdToObject doc (vla-get-Value (vlax-safearray-get-element IDPairs 0))))
    (vla-Delete TargetObject)
    (setq TargetObject (vla-ObjectIdToObject doc (vla-get-Value (vlax-safearray-get-element IDPairs 1))))
    (alert "The target objects have been deleted!")
GMT+8, 2026-11-30 10:50
