Utility 属性 (ActiveX)
获取文档的 Utility 对象。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Utility()
' This example creates a spline in model space using the
' CreateTypedArray method off of the utility object.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan As Variant
Dim endTan As Variant
Dim fitPoints As Variant
Dim utilObj As Object ' CreateTypedArray needs to be a late bound object
Set utilObj = ThisDrawing.Utility
utilObj.CreateTypedArray startTan, vbDouble, 0.5, 0.5, 0
utilObj.CreateTypedArray endTan, vbDouble, 0.5, 0.5, 0
utilObj.CreateTypedArray fitPoints, vbDouble, 1, 1, 0, 5, 5, 0, 10, 0, 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_Utility()
;; This example creates a spline in model space using the
;; CreateTypedArray method off of the utility object.
;; Create the spline
(setq utilObj (vla-get-Utility doc))
(vla-CreateTypedArray utilObj 'startTan vlax-vbDouble 0.5 0.5 0)
(vla-CreateTypedArray utilObj 'endTan vlax-vbDouble 0.5 0.5 0)
(vla-CreateTypedArray utilObj 'fitPoints vlax-vbDouble 0 0 0 5 5 0 10 0 0)
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
GMT+8, 2026-11-30 11:02
