URLNamedLocation 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 643| 评论: 0|原作者: admin|来自: AutoCAD
指定 Hyperlink 对象的命名位置。
object.URLNamedLocation
类型:超链接
此属性应用于的对象。
只读:不
类型:字符串
一个字符串,表示对象的命名位置。Hyperlink
此特性指定给定位置,例如AutoCAD中的命名视图或文字处理程序中的书签。如果在 AutoCAD 图形中指定要跳转到的命名视图,则在打开超链接时,AutoCAD 将恢复该视图。在模型空间中创建的视图将在“模型”选项卡中恢复。在图纸空间中创建的视图将在上一个活动版面选项卡中恢复。
Sub Example_URLNamedLocation()
    ' This example creates a Circle object in model space and
    ' adds a new Hyperlink to its Hyperlink collection
    Dim Hyperlinks As AcadHyperlinks
    Dim Hyperlink As AcadHyperlink
    Dim circleObj As AcadCircle
    Dim radius As Double
    Dim HLList As String
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ' Get reference to the Circle's Hyperlinks collection
    Set Hyperlinks = circleObj.Hyperlinks
    ' Add a new Hyperlink complete with all properties
    Set Hyperlink = Hyperlinks.Add("Autodesk")
    Hyperlink.URL = "www.autodesk.com"
    Hyperlink.URLDescription = "Autodesk Main Site"
    Hyperlink.URLNamedLocation = "MY_LOCATION"
    ' Read and display a list of existing Hyperlinks and
    ' their properties for this object
    For Each Hyperlink In Hyperlinks
        HLList = HLList & "____________________________________" & vbCrLf   ' Separator
        HLList = HLList & "URL: " & Hyperlink.URL & vbCrLf
        HLList = HLList & "URL Description: " & Hyperlink.URLDescription & vbCrLf
        HLList = HLList & "URL Named Location: " & Hyperlink.URLNamedLocation & vbCrLf
    Next
    MsgBox "The circle has " & Hyperlinks.count & " Hyperlink: " & vbCrLf & HLList
(defun c:Example_URLNamedLocation()
    ;; This example creates a Circle object in model space and
    ;; adds a new Hyperlink to its Hyperlink collection
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    ;; Get reference to the Circle's Hyperlinks collection
    (setq Hyperlinks (vla-get-Hyperlinks circleObj))
    ;; Add a new Hyperlink complete with all properties
    (setq Hyperlink (vla-Add Hyperlinks "Autodesk"))
    (vla-put-URL Hyperlink "www.autodesk.com")
    (vla-put-URLDescription Hyperlink "Autodesk Main Site")
    (vla-put-URLNamedLocation Hyperlink "MY_LOCATION")
    ;; Read and display a list of existing Hyperlinks and
    ;; their properties for this object
    (setq HLList "")
    (vlax-for Hyperlink Hyperlinks
        (setq HLList (strcat HLList "____________________________________"   ;; Separator
                             "\nURL: " (vla-get-URL Hyperlink)
                             "\nURL Description: " (vla-get-URLDescription Hyperlink)
                             "\nURL Named Location: " (vla-get-URLNamedLocation Hyperlink)))
    (alert (strcat "The circle has " (itoa (vla-get-Count Hyperlinks)) " Hyperlink: \n"  HLList))
GMT+8, 2026-10-17 02:16
