UCSIconAtOrigin 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 1031| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在原点显示 UCS 图标。
object.UCSIconAtOrigin
类型:PViewport、视口
此属性应用于的对象。
只读:不
类型:布尔
  • True:UCS图标显示在原点。
  • False:原点不显示 UCS 图标。
如果 UCS 图标处于打开状态(请参阅属性)且未显示在原点,则该图标将显示在 UCSORG 系统变量定义的 WCS 坐标处。UCSIconOn
Sub Example_UCSIconAtOrigin()
    ' This example toggles the setting of UCSIconAtOrigin.
    Dim viewportObj As AcadViewport
    ' Set the viewportObj variable to the activeviewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Make sure the UCS Icon is on, and a new UCS is defined.
    ' The new UCS defines the origin for the icon. When the icon
    ' is not displayed at the origin, it is displayed at the
    ' lower-left corner of the display.
    Dim ucsObj As AcadUCS
    Dim origin(0 To 2) As Double
    Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As Double
    origin(0) = 2: origin(1) = 2: origin(2) = 0
    xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
    yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
    ThisDrawing.ActiveUCS = ucsObj
    viewportObj.UCSIconOn = True
    ' Display the current setting of UCSIconAtOrigin
    MsgBox "UCSIconAtOrigin is: " & IIf(viewportObj.UCSIconAtOrigin, "On", "Off"), , "UCSIconAtOrigin Example"
    ' Toggle the setting of UCSIconAtOrigin
    viewportObj.UCSIconAtOrigin = Not (viewportObj.UCSIconAtOrigin)
    ' Reset the active viewport to see the change
    ThisDrawing.ActiveViewport = viewportObj
    MsgBox "UCSIconAtOrigin is now: " & IIf(viewportObj.UCSIconAtOrigin, "On", "Off"), , "UCSIconAtOrigin Example"
(defun c:Example_UCSIconAtOrigin()
    ;; This example toggles the setting of UCSIconAtOrigin.
    ;; Set the viewportObj variable to the activeviewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Make sure the UCS Icon is on, and a new UCS is defined.
    ;; The new UCS defines the origin for the icon. When the icon
    ;; is not displayed at the origin, it is displayed at the
    ;; lower-left corner of the display.
    (setq origin (vlax-3d-point 2 2 0)
          xAxisPoint (vlax-3d-point 3 2 0)
          yAxisPoint (vlax-3d-point 2 3 0))
    (setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "UCS1"))
    (vla-put-ActiveUCS doc ucsObj)
    (vla-put-UCSIconOn viewportObj :vlax-true)
    ;; Display the current setting of UCSIconAtOrigin
    (alert (strcat "UCSIconAtOrigin is: " (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) "On" "Off")))
    ;; Toggle the setting of UCSIconAtOrigin
    (vla-put-UCSIconAtOrigin viewportObj (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) :vlax-false :vlax-true))
    ;; Reset the active viewport to see the change
    (vla-put-ActiveViewport doc viewportObj)
    (alert (strcat "UCSIconAtOrigin is now: " (if (= (vla-get-UCSIconAtOrigin viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-11-29 14:18
