TwistAngle 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 631| 评论: 0|原作者: admin|来自: AutoCAD
指定视口的扭转角度。
object.TwistAngle
类型: PViewport
此属性应用于的对象。
只读:不
类型:双
以弧度为单位的扭转角。
此方法会扭曲或倾斜视线周围的视图。AutoCAD 逆时针测量扭转角度,向右 0 度。
Sub Example_TwistAngle()
    ' This example creates a new paper space viewport.
    ' It then displays the twist angle of the viewport.
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the pviewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ' Change from model space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the pviewport
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    pviewportObj.Display True
    ThisDrawing.MSpace = True
    ThisDrawing.ActivePViewport = pviewportObj
    ' Find the twist angle for the viewport
    Dim twistAngle As Double
    twistAngle = pviewportObj.TwistAngle
    MsgBox "The twist angle of the paper space viewport is " & pviewportObj.twistAngle, , "TwistAngle Example"
(defun c:Example_TwistAngle()
    ;; This example creates a new paper space viewport.
    ;; It then displays the twist angle of the viewport.
    ;; Define the pviewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
          height 40)
    ;; Change from model space to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the pviewport
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    (vla-Display pviewportObj :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc pviewportObj)
    ;; Find the twist angle for the viewport
    (setq twistAngle (vla-get-TwistAngle pviewportObj))
    (alert (strcat "The twist angle of the paper space viewport is " (rtos twistAngle 2)))
GMT+8, 2026-11-11 15:09
