ToleranceLowerLimit 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 714| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸文本的最小容差限制。
object.ToleranceLowerLimit
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
公差下限。
此属性的初始值为 0.0000。
仅当该属性设置为 或 时,此属性才可用。ToleranceDisplayacTolDeviationacTolLimits
注意:此属性将覆盖给定维度的 DIMTM 系统变量的值。
Sub Example_ToleranceLowerLimit()
    ' sets the tolerance limits using the ToleranceLowerLimit and
    ' ToleranceUpperLimit properties
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Turn on tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    ' Read and display the tolerance limits for the dimension
    MsgBox "The tolerance lower limit is set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _
           "The tolerance upper limit is set to: " & dimObj.ToleranceUpperLimit
    ' Adjust the tolerance limits for this dimension
    dimObj.ToleranceLowerLimit = 0.0001
    dimObj.ToleranceUpperLimit = 0.005
    MsgBox "The tolerance lower limit is now set to: " & dimObj.ToleranceLowerLimit & vbCrLf & _
           "The tolerance upper limit is now set to: " & dimObj.ToleranceUpperLimit
(defun c:Example_ToleranceLowerLimit()
    ;; sets the tolerance limits using the ToleranceLowerLimit and
    ;; ToleranceUpperLimit properties
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    ;; Turn on tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-ZoomAll acadObj)
    ;; Read and display the tolerance limits for the dimension
    (alert (strcat "The tolerance lower limit is set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2)
                   "\nThe tolerance upper limit is set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2)))
    ;; Adjust the tolerance limits for this dimension
    (vla-put-ToleranceLowerLimit dimObj 0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.005)
    (alert (strcat "The tolerance lower limit is now set to: " (rtos (vla-get-ToleranceLowerLimit dimObj) 2)
                   "\nThe tolerance upper limit is now set to: " (rtos (vla-get-ToleranceUpperLimit dimObj) 2)))
GMT+8, 2026-10-17 05:10
