ToleranceHeightScale 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 805| 评论: 0|原作者: admin|来自: AutoCAD
指定公差值的文本高度相对于尺寸文本高度的比例因子。
object.ToleranceHeightScale
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
公差值的比例因子。
此属性的初始值为 1.0000。
仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone
当 DIMTOL 处于打开状态且 DIMTM 不等于 DIMTP 时,或者当 DIMLIM 处于打开状态时,将此属性用于正负容差字符串。
注意:此属性将覆盖给定维度的 DIMTFAC 系统变量的值。
Sub Example_ToleranceHeightScale()
    ' turns on the tolerance display for the new dimension.  The height
    ' of the tolerance text can then be adjusted by the user
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    Dim CurrentScale As Integer
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Turn on the tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
Increase:
    ' Read and display the current tolerance height scale for this dimension
    If MsgBox("The tolerance height scale is currently set to: " & dimObj.ToleranceHeightScale & vbCrLf & _
              "Press OK to increase, or cancel to finish", vbOKCancel) = vbCancel Then
        Exit Sub
    End If
    ' Increase the tolerance height scale for this dimension
    dimObj.ToleranceHeightScale = dimObj.ToleranceHeightScale + 1
    GoTo Increase
(defun c:Example_ToleranceHeightScale()
    ;; turns on the tolerance display for the new dimension.  The height
    ;; of the tolerance text can then be adjusted by the user
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    ;; Turn on the tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-ZoomAll acadObj)
    ;; Read and display the current tolerance height scale for this dimension
    (alert (strcat "The tolerance height scale is currently set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2)))
    ;; Increase the tolerance height scale for this dimension
    (vla-put-ToleranceHeightScale dimObj (1+ (vla-get-ToleranceHeightScale dimObj)))
    (alert (strcat "The tolerance height scale is now set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2)))
GMT+8, 2026-11-29 23:48
