TextWinTextColor 属性 (ActiveX)
指定文本窗口的文本颜色。 支持的平台:仅限 Windows 属性值只读:是/否 类型:OLE_COLOR(常量)
言论此属性的默认颜色是 Windows 标准窗口文本颜色。 例子VBA: Sub Example_TextWinTextColor()
' TextWinTextColor. It then changes the value, and finally
Dim currTextWinTextColor As Long
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextWinTextColor value
currTextWinTextColor = preferences.Display.TextWinTextColor
MsgBox "The current value for TextWinTextColor is " _
& preferences.Display.TextWinTextColor, vbInformation, "TextWinTextColor Example"
' Change the value for TextWinTextColor
preferences.Display.TextWinTextColor = vbGreen
MsgBox "The new value for TextWinTextColor is " _
' Reset TextWinTextColor to its original value
preferences.Display.TextWinTextColor = currTextWinTextColor
MsgBox "The TextWinTextColor value is reset to " _
可视化 LISP: (vl-load-com)
(defun c:Example_TextWinTextColor()
;; TextWinTextColor. It then changes the value, and finally
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
;; Retrieve the current TextWinTextColor value
(setq currTextWinTextColor (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong))
(alert (strcat "The current value for TextWinTextColor is " (itoa (vlax-variant-value currTextWinTextColor))))
;; Change the value for TextWinTextColor
(vla-put-TextWinTextColor ACADPref (vlax-make-variant acGreen 19))
(setq newValue (vlax-variant-change-type (vla-get-TextWinTextColor ACADPref) vlax-vbLong))
(alert (strcat "The new value for TextWinTextColor is " (itoa (vlax-variant-value newValue))))
;; Reset TextWinTextColor to its original value
(vla-put-TextWinTextColor ACADPref (vlax-variant-change-type currTextWinTextColor 19))
(alert (strcat "The TextWinTextColor value is reset to " (itoa (vlax-variant-value currTextWinTextColor))))
GMT+8, 2026-11-29 10:47
