TextSuffix 属性 (ActiveX)
指定维度值后缀。 支持的平台:仅限 Windows 签名VBA: object.TextSuffix 属性值只读:不 类型:字符串 维度值的后缀。 言论此属性的初始值为“”。 注意:此属性将覆盖给定维度的 DIMPOST 系统变量的值。
例子VBA: Sub Example_TextSuffix()
' uses TextSuffix to allow the user to change the text suffix for the
' dimension
Dim dimObj As AcadDimAligned
Dim suffix As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Allow the user to change the text suffix for the dimension
suffix = InputBox("Enter a new text suffix for the dimension", "Set Dimension Suffix", ":SUFFIX")
dimObj.TextSuffix = suffix ' Commit changes to suffix
' Read back and display the dimension text suffix
suffix = dimObj.TextSuffix
If suffix <> "" Then
MsgBox "The suffix of the dimension has been changed to: " & suffix
Else
MsgBox "The suffix of the dimension has been removed"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_TextSuffix()
;; uses TextSuffix to allow the user to change the text suffix for the
;; dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
(vla-ZoomAll acadObj)
;; Allow the user to change the text suffix for the dimension
(setq suffix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text suffix for the dimension: "))
(vla-put-TextSuffix dimObj suffix) ;; Commit changes to suffix
;; Read back and display the dimension text suffix
(setq suffix (vla-get-TextSuffix dimObj))
(if (/= suffix "")
(alert (strcat "The suffix of the dimension has been changed to: " suffix))
(alert "The suffix of the dimension has been removed")
GMT+8, 2026-11-29 14:04
