TextRotation 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 815| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸文本的旋转角度。
object.TextRotation
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、MLeader
此属性应用于的对象。
只读:不
类型:双
尺寸文本的角度(以弧度为单位)。有效范围为 0 到 6.28。
默认情况下,此值等于 0 度,或等于 Rotation 属性,由尺寸样式指定。
0 度角的文本
角度等于尺寸旋转的文本
Sub Example_TextRotation()
    ' This example creates an aligned dimension and then changes the
    ' TextRotation property for that dimension.
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    ' Define the dimension
    point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
    location(0) = 7.5: location(1) = 5#: location(2) = 0#
    ZoomAll
    MsgBox "The current text rotation angle for the dimension is " & dimObj.TextRotation & " radians.", vbInformation, "TextRotation Example"
    ' Change the text rotation angle to 45 degrees (.707 radians)
    dimObj.TextRotation = 0.707
    dimObj.Update
    MsgBox "The new text rotation angle for the dimension is " & dimObj.TextRotation & " radians.", vbInformation, "TextRotation Example"
(defun c:Example_TextRotation()
    ;; This example creates an aligned dimension and then changes the
    ;; TextRotation property for that dimension.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 5 3 0)
          point2 (vlax-3d-point 10 3 0)
          location (vlax-3d-point 7.5 5 0))
    (vla-ZoomAll acadObj)
    (alert (strcat "The current text rotation angle for the dimension is " (rtos (vla-get-TextRotation dimObj) 2) " radians."))
    ;; Change the text rotation angle to 45 degrees (.707 radians)
    (vla-put-TextRotation dimObj 0.707)
    (vla-Update dimObj)
    (alert (strcat "The new text rotation angle for the dimension is " (rtos (vla-get-TextRotation dimObj) 2) " radians."))
GMT+8, 2026-11-29 10:57
