TextPrefix 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 764| 评论: 0|原作者: admin|来自: AutoCAD
指定维度值前缀。
object.TextPrefix
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:字符串
维度值的前缀。
此属性的初始值为“”。
注意:此属性将覆盖给定维度的 DIMPOST 系统变量的值。
Sub Example_TextPrefix()
    ' uses TextPrefix to allow the user to change the text prefix for the
    ' dimension
    Dim dimObj As AcadDimAligned
    Dim prefix As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Allow the user to change the text prefix for the dimension
    prefix = InputBox("Enter a new text prefix for the dimension", "Set Dimension Prefix", "PREFIX:")
    dimObj.TextPrefix = prefix   ' Commit changes to prefix
    ' Read back and display the dimension text prefix
    prefix = dimObj.TextPrefix
    If prefix <> "" Then
        MsgBox "The prefix of the dimension has been changed to: " & prefix
    Else
        MsgBox "The prefix of the dimension has been removed"
    End If
(defun c:Example_TextPrefix()
    ;; uses TextPrefix to allow the user to change the text prefix for the
    ;; dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    (vla-ZoomAll acadObj)
    ;; Allow the user to change the text prefix for the dimension
    (setq prefix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text prefix for the dimension: "))
    (vla-put-TextPrefix dimObj prefix)   ;; Commit changes to prefix
    ;; Read back and display the dimension text prefix
    (setq prefix (vla-get-TextPrefix dimObj))
    (if (/= prefix "")
        (alert (strcat "The prefix of the dimension has been changed to: " prefix))
        (alert "The prefix of the dimension has been removed")
GMT+8, 2026-10-18 23:13
