TextPosition 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 956| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸文本位置。
object.TextPosition
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示尺寸文本位置的 3D WCS 坐标。
Sub Example_TextPosition()
    ' This example creates an aligned dimension and then changes the
    ' TextPosition property for that dimension.
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    ' Define the dimension
    point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
    location(0) = 7.5: location(1) = 5#: location(2) = 0#
    ZoomAll
    MsgBox "The current text position for the dimension is " & dimObj.TextPosition(0) & ", " & dimObj.TextPosition(1) & ", " & dimObj.TextPosition(2), vbInformation, "TextPosition Example"
    ' Change the text position location
    location(0) = 8.5: location(1) = 7: location(2) = 0
    dimObj.TextPosition = location
    dimObj.Update
    ' Return the endpoint of the first extension line
    ' Note that the return value is a Variant
    Dim retPoint As Variant
    retPoint = dimObj.TextPosition
    MsgBox "The new text position for the dimension is " & dimObj.TextPosition(0) & ", " & dimObj.TextPosition(1) & ", " & dimObj.TextPosition(2), vbInformation, "TextPosition Example"
(defun c:Example_TextPosition()
    ;; This example creates an aligned dimension and then changes the
    ;; TextPosition property for that dimension.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 5 3 0)
          point2 (vlax-3d-point 10 3 0)
          location (vlax-3d-point 7.5 5 0))
    (vla-ZoomAll acadObj)
    (setq textPosition (vlax-variant-value (vla-get-TextPosition dimObj)))
    (alert (strcat "The current text position for the dimension is " (rtos (vlax-safearray-get-element textPosition 0) 2) ", "
        (rtos (vlax-safearray-get-element textPosition 1) 2) ", "
        (rtos (vlax-safearray-get-element textPosition 2) 2)))
    ;; Change the text position location
    (setq location (vlax-3d-point 8.5 7 0))
    (vla-put-TextPosition dimObj location)
    (vla-Update dimObj)
    ;; Return the endpoint of the first extension line
    ;; Note that the return value is a Variant
    (setq retPoint (vlax-variant-value (vla-get-TextPosition dimObj)))
    (alert (strcat "The new text position for the dimension is " (rtos (vlax-safearray-get-element retPoint 0) 2) ", "
        (rtos (vlax-safearray-get-element retPoint 1) 2) ", "
        (rtos (vlax-safearray-get-element retPoint 2) 2)))
GMT+8, 2026-11-25 15:26
