TextOutsideAlign 属性 (ActiveX)
指定除纵坐标外的所有尺寸类型的扩展线外的尺寸文本的位置。 支持的平台:仅限 Windows 签名VBA: object.TextOutsideAlign
属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性将覆盖给定维度的 DIMTOH 系统变量的值。
例子VBA: Sub Example_TextOutsideAlign()
' allows the user to toggle the TextOutsideAlign value for the dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.5: point2(1) = 5.5: point2(2) = 0
Toggle:
Select Case MsgBox("Press OK to toggle the TextOutsideAlign value for this dimension", vbOKCancel)
Case vbOK
' Toggle the TextOutsideAlign value for this dimension
dimObj.TextOutsideAlign = Not (dimObj.TextOutsideAlign)
dimObj.Update
ThisDrawing.Regen acActiveViewport
' Read and display the new dimension TextOutsideAlign value
MsgBox "TextOutsideAlign is currently set to: " & dimObj.TextOutsideAlign
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_TextOutsideAlign()
;; allows the user to toggle the TextOutsideAlign value for the dimension
;; Define the dimension
point2 (vlax-3d-point 5.5 5.5 0)
(vla-ZoomAll acadObj)
;; Toggle the TextOutsideAlign value for this dimension
(vla-put-TextOutsideAlign dimObj (if (= (vla-get-TextOutsideAlign dimObj) :vlax-true) :vlax-false :vlax-true))
(vla-Update dimObj)
(vla-Regen doc acActiveViewport)
;; Read and display the new dimension TextOutsideAlign value
(alert (strcat "TextOutsideAlign is currently set to: " (if (= (vla-get-TextOutsideAlign dimObj) :vlax-true) "True" "False")))
(vla-Update dimObj)
GMT+8, 2026-10-17 21:00
