TextHeight 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 605| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸或公差文本的高度。
object.TextHeight
类型:Dim3PointAngularDimAlignedDimAngularDimArcLengthDimDiametricDimensionDimOrdinateDimRadialDimRadialLargeDimRotatedMLeader、MLeaderStyleTolerance
此属性应用于的对象。
只读:
类型:
尺寸文本的高度。
此属性的初始值为 0.1800。
如果当前文本样式具有固定的文本高度,则忽略此属性。
注意:此属性将覆盖给定维度的 DIMTXT 系统变量的值。
Sub Example_TextHeight()
    ' uses the TextHeight property to increase the height of the
    ' dimension text
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Read and display current dimension text height
    MsgBox "The dimension text height for this object is currently set to: " & dimObj.textHeight
    ' Increase the distance of the dimension gap
    dimObj.TextHeight = 1
    MsgBox "The dimension text height for this object is now set to: " & dimObj.textHeight
(defun c:Example_TextHeight()
    ;; uses the TextHeight property to increase the height of the
    ;; dimension text
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current dimension text height
    (alert (strcat "The dimension text height for this object is currently set to: " (rtos (vla-get-TextHeight dimObj) 2)))
    ;; Increase the distance of the dimension gap
    (vla-put-TextHeight dimObj 1)
    (alert (strcat "The dimension text height for this object is now set to: " (rtos (vla-get-TextHeight dimObj) 2)))
GMT+8, 2026-9-15 03:13
