TextGenerationFlag 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 602| 评论: 0|原作者: admin|来自: AutoCAD
指定属性文本生成标志。
object.TextGenerationFlag
类型:Attribute、AttributeReference、Text、TextStyle
此属性应用于的对象。
只读:不
类型:枚举acTextGenerationFlag
  • acTextFlagBackward
  • acTextFlagUpsideDown
若要指定这两个标志,请将它们相加。
Sub Example_TextGenerationFlag()
    ' This example creates a text object in model space.
    ' It then changes the TextGenerationFlag of the text object.
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
    MsgBox "The TextGenerationFlag has not been set.", vbInformation, "TextGenerationFlag Example"
    ' Change the value of the TextGenerationFlag
    textObj.TextGenerationFlag = acTextFlagBackward
    ZoomAll
    MsgBox "The TextGenerationFlag is set to acTextFlagBackward.", vbInformation, "TextGenerationFlag Example"
    textObj.TextGenerationFlag = acTextFlagUpsideDown
    ZoomAll
    MsgBox "The TextGenerationFlag is set to acTextFlagUpsideDown.", vbInformation, "TextGenerationFlag Example"
    textObj.TextGenerationFlag = acTextFlagBackward + acTextFlagUpsideDown
    ZoomAll
    MsgBox "The TextGenerationFlag is set to acTextFlagBackward + acTextFlagUpsideDown.", vbInformation, "TextGenerationFlag Example"
(defun c:Example_TextGenerationFlag()
    ;; This example creates a text object in model space.
    ;; It then changes the TextGenerationFlag of the text object.
    ;; Define the text object
    (setq insertionPoint (vlax-3d-point 3 3 0)
          textString "Hello, World."
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    (alert "The TextGenerationFlag has not been set.")
    ;; Change the value of the TextGenerationFlag
    (vla-put-TextGenerationFlag textObj acTextFlagBackward)
    (alert "The TextGenerationFlag is set to acTextFlagBackward.")
    (vla-put-TextGenerationFlag textObj acTextFlagUpsideDown)
    (alert "The TextGenerationFlag is set to acTextFlagUpsideDown.")
    (vla-put-TextGenerationFlag textObj (+ acTextFlagBackward acTextFlagUpsideDown))
    (alert "The TextGenerationFlag is set to acTextFlagBackward + acTextFlagUpsideDown.")
GMT+8, 2026-11-29 10:49
