TextEditor 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 679| 评论: 0|原作者: admin|来自: AutoCAD
指定 MTEXT 命令的文本编辑器的名称。
object.TextEditor
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
多行文本编辑器的名称。
Sub Example_TextEditor()
    ' TextEditor. It then changes the value, and finally
    Dim currTextEditor As String
    Dim newTextEditor As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current TextEditor value
    currTextEditor = preferences.Files.TextEditor
    MsgBox "The current value for TextEditor is " & currTextEditor, vbInformation, "TextEditor Example"
    ' Change the value for TextEditor
    newTextEditor = "TestTextEditor"
    preferences.Files.TextEditor = newTextEditor
    MsgBox "The new value for TextEditor is " & newTextEditor, vbInformation, "TextEditor Example"
    ' Reset TextEditor to its original value
    preferences.Files.TextEditor = currTextEditor
    MsgBox "The TextEditor value is reset to " & currTextEditor, vbInformation, "TextEditor Example"
(defun c:Example_TextEditor()
    ;; TextEditor. It then changes the value, and finally
    ;; Retrieve the current TextEditor value
    (setq currTextEditor (vla-get-TextEditor (vla-get-Files preferences)))
    (alert (strcat "The current value for TextEditor is " currTextEditor))
    ;; Change the value for TextEditor
    (setq newTextEditor "TestTextEditor")
    (vla-put-TextEditor (vla-get-Files preferences) newTextEditor)
    (alert (strcat "The new value for TextEditor is " newTextEditor))
    ;; Reset TextEditor to its original value
    (vla-put-TextEditor (vla-get-Files preferences) currTextEditor)
    (alert (strcat "The TextEditor value is reset to " currTextEditor))
GMT+8, 2026-11-30 10:58
