TextAlignmentPoint 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 725| 评论: 0|原作者: admin|来自: AutoCAD
指定文本和属性的对齐点。
object.TextAlignmentPoint
类型:属性、属性引用、文本
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示对象对齐点的 3D WCS 坐标。
文本:此属性将重置为 0、0、0,当属性设置为 时,此属性将变为只读。若要放置对齐方式为“left”、“fit”或“aligned”的文本,请使用该属性。AlignmentacAlignmentLeftInsertionPoint
Sub Example_TextAlignmentPoint()
    ' This example creates a text object in model space.
    ' It then changes the TextAlignmentPoint and HorizontalAlignment
    ' properties of the text object.
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
    MsgBox "The TextAlignmentPoint is set to the default " & _
           textObj.TextAlignmentPoint(0) & ", " & _
           textObj.TextAlignmentPoint(1) & ", " & _
           textObj.TextAlignmentPoint(2), vbInformation, _
           "TextAlignmentPoint Example"
    ' Change the value of the HorizontalAlignment and
    ' TextAlignmentPoint properties.
    ' Note that the HorizontalAlignment property must be changed first,
    ' and to a value that requires the TextAlignmentPoint, before the
    ' TextAlignmentPoint property will allow a value to be set.
    Dim alignmentPoint(0 To 2) As Double
    alignmentPoint(0) = 5: alignmentPoint(1) = 3: alignmentPoint(2) = 0
    textObj.HorizontalAlignment = acHorizontalAlignmentFit
    textObj.TextAlignmentPoint = alignmentPoint
    ZoomAll
    MsgBox "The TextAlignmentPoint is set to " & _
           textObj.TextAlignmentPoint(2) & vbCrLf & _
           "The HorizontalAlignment is set to acHorizontalAlignmentFit", _
           vbInformation, "TextAlignmentPoint Example"
(defun c:Example_TextAlignmentPoint()
    ;; This example creates a text object in model space.
    ;; It then changes the TextAlignmentPoint and HorizontalAlignment
    ;; properties of the text object.
    ;; Define the text object
    (setq insertionPoint (vlax-3d-point 3 3 0)
          textString "Hello, World."
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    (setq alignmentPoint (vlax-variant-value (vla-get-TextAlignmentPoint textObj)))
    (alert (strcat "The TextAlignmentPoint is set to the default " (rtos (vlax-safearray-get-element alignmentPoint 0) 2) ", "
        (rtos (vlax-safearray-get-element alignmentPoint 1) 2) ", "
        (rtos (vlax-safearray-get-element alignmentPoint 2) 2)))
    ;; Change the value of the HorizontalAlignment and
    ;; TextAlignmentPoint properties.
    ;; Note that the HorizontalAlignment property must be changed first,
    ;; and to a value that requires the TextAlignmentPoint, before the
    ;; TextAlignmentPoint property will allow a value to be set.
    (setq alignmentPoint (vlax-3d-point 5 3 0))
    (vla-put-Alignment textObj acHorizontalAlignmentFit)
    (vla-put-TextAlignmentPoint textObj alignmentPoint)
    (alert (strcat "The TextAlignmentPoint is set to " (rtos (vlax-safearray-get-element alignmentPoint 0) 2) ", "
GMT+8, 2026-11-30 10:50
