TemplateDWGPath 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
指定启动向导使用的模板文件的路径。
object.TemplateDWGPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
模板文件的驱动器和路径。
Sub Example_TemplateDWGPath()
    ' TemplateDWGPath. It then changes the value, and finally
    Dim currTemplateDWGPath As String
    Dim newTemplateDWGPath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current TemplateDWGPath value
    currTemplateDWGPath = preferences.Files.TemplateDwgPath
    MsgBox "The current value for TemplateDWGPath is " & currTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
    ' Change the value for TemplateDWGPath
    newTemplateDWGPath = "TestTemplateDWGPath"
    preferences.Files.TemplateDwgPath = newTemplateDWGPath
    MsgBox "The new value for TemplateDWGPath is " & newTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
    ' Reset TemplateDWGPath to its original value
    preferences.Files.TemplateDwgPath = currTemplateDWGPath
    MsgBox "The TemplateDWGPath value is reset to " & currTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
(defun c:Example_TemplateDwgPath()
    ;; TemplateDwgPath. It then changes the value, and finally
    ;; Retrieve the current TemplateDWGPath value
    (setq currTemplateDWGPath (vla-get-TemplateDwgPath (vla-get-Files preferences)))
    (alert (strcat "The current value for TemplateDwgPath is " currTemplateDWGPath))
    ;; Change the value for TemplateDWGPath
    (setq newTemplateDWGPath "TestTemplateDWGPath")
    (vla-put-TemplateDwgPath (vla-get-Files preferences) newTemplateDWGPath)
    (alert (strcat "The new value for TemplateDwgPath is " newTemplateDWGPath))
    ;; Reset TemplateDWGPath to its original value
    (vla-put-TemplateDwgPath (vla-get-Files preferences) currTemplateDWGPath)
    (alert (strcat "The TemplateDwgPath value is reset to " currTemplateDWGPath))
GMT+8, 2026-10-27 10:47
