TabOrder 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 835| 评论: 0|原作者: admin|来自: AutoCAD
指定布局的 Tab 键顺序。
object.TabOrder
类型: 布局
此属性应用于的对象。
只读:不
类型:长
布局的 Tab 键顺序。
此属性控制布局在选项卡控件中的显示顺序。在数据库中的所有布局中,Tab 键顺序应该是唯一的和连续的。
模型空间选项卡的 Tab 键顺序必须为零 (0)。纸张空间选项卡的 Tab 键顺序必须为 1 或更大。
Sub Example_TabOrder()
    ' This example creates two new Layouts, sets the TabOrder of the Layouts to be
    ' in alphabetic order, and displays a list of Layouts in the order they appear
    ' in the tabs.
    Dim Layout1 As ACADLayout, Layout2 As ACADLayout
    Dim SortLayoutRight As ACADLayout, SortLayoutLeft As ACADLayout
    Dim SortIt As New Collection
    Dim TabCount As Long, SortCount As Long, TabOrder As Long
    Dim TabName As String, SortText As String, msg As String
    Dim tempLayout As ACADLayout
    Dim AddedTab As Boolean
    ' Create new Layouts
    On Error Resume Next
    Set Layout1 = ThisDrawing.Layouts.Add("Z VIEW")
    Set Layout2 = ThisDrawing.Layouts.Add("A VIEW")
    On Error GoTo 0
    ' Alphabetize internally
    For TabCount = 0 To (ThisDrawing.Layouts.count - 1)
        AddedTab = False
        TabName = ThisDrawing.Layouts(TabCount).name
        If TabName = "Model" Then GoTo SKIP                 ' Skip modelspace
        If SortIt.count = 0 Then
            SortIt.Add TabName                              ' Add to beginning of list
        Else
            For SortCount = 1 To SortIt.count               ' Add to list by string
                SortText = SortIt(SortCount)
                If StrComp(TabName, SortText, vbTextCompare) = -1 Then
                    If SortCount = 1 Then
                        SortIt.Add TabName                  ' Add as first item
                    Else
                        SortIt.Add TabName, , SortCount     ' Add as previous item
                    End If
                    AddedTab = True
                    Exit For
                End If
            Next
            If Not (AddedTab) Then SortIt.Add TabName, , , SortIt.count  ' Add if we haven't yet
        End If
SKIP:
    Next
    ' Write new ACAD tab order
        Set tempLayout = ThisDrawing.Layouts(SortIt(SortCount))
        tempLayout.TabOrder = SortCount
    Next
    ' Read and display New Tab Order
    msg = "The tab order is now set to: " & vbCrLf & vbCrLf
        If TabName = "Model" Then GoTo SKIP2                ' Don't show modelspace
        TabOrder = ThisDrawing.Layouts(TabCount).TabOrder
        msg = msg & "(" & TabOrder & ")" & vbTab & TabName & vbCrLf
SKIP2:
    Next
    MsgBox msg, vbInformation
(defun c:Example_TabOrder()
    ;; This example creates two new Layouts, sets the TabOrder of the Layouts to be
    ;; in alphabetic order, and displays a list of Layouts in the order they appear
    ;; in the tabs.
    ;; Create new Layouts
    (setq Layout1 (vla-Add (vla-get-Layouts doc) "Z VIEW"))
    (setq Layout2 (vla-Add (vla-get-Layouts doc) "A VIEW"))
    (setq SortIt (list)
          TabCount 0)
    ;; Alphabetize internally
    (while (>= (1- (vla-get-Count (vla-get-Layouts doc))) TabCount)
        (setq AddedTab :vlax-false)
        (setq TabName (vla-get-Name (vla-Item (vla-get-Layouts doc) TabCount)))
        (if (/= (strcase TabName) "MODEL")                  ;; Skip modelspace
            (progn
	               (setq SortIt (append SortIt (list TabName)))        ;; Add to beginning of list
        (setq TabCount (1+ TabCount))
    ;; Sort layout names
    (setq SortIt (acad_strlsort SortIt)
          SortCount 1)
    ;; Update tab order
    (foreach name SortIt
        (progn
            (setq tempLayout (vla-Item (vla-get-Layouts doc) name))
            (vla-put-TabOrder tempLayout SortCount)
            (setq SortCount (1+ SortCount))
    ;; Read and display New Tab Order
    (setq msg "The tab order is now set to: \n"
          TabCount 0)
            (progn
                (setq TabOrder (vla-get-TabOrder (vla-Item (vla-get-Layouts doc) TabCount)))
                (setq msg (strcat msg "(" (itoa TabOrder) ")    " TabName "\n"))
    (alert msg)
GMT+8, 2026-10-28 08:18
