TableBreakHeight 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 827| 评论: 0|原作者: admin|来自: AutoCAD
设置初始工作台零件和任何其他未设置手动高度的工作台零件的断裂高度。
object.TableBreakHeight
类型: 表格
此属性应用于的对象。
只读:不
类型:双
断裂高度的值。
Sub Example_BreakHeight()
    ' This example creates a table object and then breaks it into
    ' two tables.
    ' Create a new table objetc in model space
    Dim pt(2) As Double
    Dim modelSpace As AcadModelSpace
    Set modelSpace = ThisDrawing.modelSpace
    Dim table As AcadTable
    Set table = modelSpace.AddTable(pt, 5, 5, 10, 30)
    table.EnableBreak = True
    table.BreakSpacing = 3.5
    table.TableBreakHeight = 35#
    table.AllowManualHeights = True
    table.SetBreakHeight 0, 20#
    table.SetBreakHeight 1, 35#
    ZoomExtents
(defun c:Example_BreakHeight()
    ;; This example creates a table object and then breaks it into
    ;; two tables.
    ;; Create a new table objetc in model space
    (setq pt (vlax-3d-point 0 0 0))
    (setq table (vla-Addtable modelSpace pt 5 5 10 30))
    (vla-put-EnableBreak table :vlax-true)
    (vla-put-BreakSpacing table 3.5)
    (vla-put-TableBreakHeight table 35.0)
    (vla-put-AllowManualHeights table :vlax-true)
    (vla-SetBreakHeight table 0 20.0)
    (vla-SetBreakHeight table 1 35.0)
    (vla-ZoomExtents acadObj)
GMT+8, 2026-10-27 19:11
