System 属性 (ActiveX)
获取 PreferencesSystem 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“系统”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesSystemDatabasePreferences 例子VBA: Sub Example_System()
' This example obtains a reference to the System Preferences object
' from the Application Preferences object, and reads one of the System
' preferences
Dim ACADPref As AcadPreferencesSystem
' Obtain a reference to the System Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.System
MsgBox "You now have access to the properties and methods of the System Preferences object!"
MsgBox "The System preference BeepOnError is set to: " & ACADPref.BeepOnError
可视化 LISP: (vl-load-com)
(defun c:Example_System()
;; This example obtains a reference to the System Preferences object
;; from the Application Preferences object, and reads one of the System
;; preferences
(alert "You now have access to the properties and methods of the System Preferences object!")
(alert (strcat "The System preference BeepOnError is set to: " (if (= (vla-get-BeepOnError (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-26 18:20
