SubMenu 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 909| 评论: 0|原作者: admin|来自: AutoCAD
获取与子菜单关联的弹出菜单。
object.SubMenu
类型:PopupMenuItem
此属性应用于的对象。
只读:是的
类型:PopupMenu
与子菜单关联的弹出菜单。
如果弹出菜单项不是子菜单,则此属性将返回错误。
Sub Example_SubMenu()
    ' This example finds the menu used as the sub menu for the
    ' "Additional Resources" menu item in the Help menu.
    Dim acadMenuGroup As acadMenuGroup
    Set acadMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
    Dim helpMenu As AcadPopupMenu
    Set helpMenu = acadMenuGroup.Menus.Item("&Help")
    Dim menuItem As AcadPopupMenuItem
    Set menuItem = helpMenu.Item(4)
    Dim subMenu As AcadPopupMenu
    Set subMenu = menuItem.subMenu
    MsgBox "The name of the submenu is " & subMenu.TagString
(defun c:Example_SubMenu()
    ;; This example finds the menu used as the sub menu for the
    ;; "Additional Resources" menu item in the Help menu.
    (setq acadMenuGroup (vla-Item (vla-get-MenuGroups acadObj) "ACAD"))
    (setq helpMenu (vla-Item (vla-get-Menus acadMenuGroup) "&Help"))
    (setq menuItem (vla-Item helpMenu 4))
    (setq subMenu (vla-get-SubMenu menuItem))
    (alert (strcat "The name of the submenu is " (vla-get-TagString subMenu)))
GMT+8, 2026-11-29 10:48
