StoreSQLIndex 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 880| 评论: 0|原作者: admin|来自: AutoCAD
确定 SQL 索引是否存储在图形中。
object.StoreSQLIndex
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:在图形中存储 SQL 索引。
  • False:不将 SQL 索引存储在图形中。
此属性的初始值为 。True
Sub Example_StoreSQLIndex()
    ' This example reads and modifies the preference value that controls
    ' whether the SQL index is stored in the drawing.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSystem
    ' Get the system preferences object
    Set ACADPref = ThisDrawing.Application.preferences.System
    originalValue = ACADPref.StoreSQLIndex
    MsgBox "The StoreSQLIndex preference is set to: " & originalValue
    ' Modify the StoreSQLIndex preference by toggling the value
    ACADPref.StoreSQLIndex = Not (ACADPref.StoreSQLIndex)
    newValue = ACADPref.StoreSQLIndex
    MsgBox "The StoreSQLIndex preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.StoreSQLIndex = originalValue
    MsgBox "The StoreSQLIndex preference was reset back to: " & originalValue
(defun c:Example_StoreSQLIndex()
    ;; This example reads and modifies the preference value that controls
    ;; whether the SQL index is stored in the drawing.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-StoreSQLIndex (vla-get-System preferences)))
    (alert (strcat "The StoreSQLIndex preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the StoreSQLIndex preference by toggling the value
    (vla-put-StoreSQLIndex (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The StoreSQLIndex preference has been set to: " (if (= (vla-get-StoreSQLIndex (vla-get-System preferences)) :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-StoreSQLIndex (vla-get-System preferences) originalValue)
    (alert (strcat "The StoreSQLIndex preference was reset back to: " (if (= (vla-get-StoreSQLIndex (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 09:43
