StartPoint 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 832| 评论: 0|原作者: admin|来自: AutoCAD
指定圆弧、直线或椭圆的起点。
object.StartPoint
类型:圆弧椭圆直线
此属性应用于的对象。
只读:是,但 Line 对象除外,该对象是读写的
类型:变体(双打的三元素阵列)
表示对象起点的 3D 坐标。
圆弧、椭圆和直线的起点
不能更改圆弧或椭圆的起点。要编辑圆弧,请使用 和 属性。若要编辑椭圆,请使用 、 和 属性。EndAngleRadiusEndAngleMajorAxisRadiusRatio
Sub Example_StartPoint()
    ' This example creates an elliptical arc and then
    ' finds the coordinates of its start point and endpoint.
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    Dim startPoint As Variant
    Dim endPoint As Variant
    ' Create an ellipse in model space
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ' Enter a start angle of 45 degrees, and an end angle of 270 degrees
    ellObj.startAngle = 45 * (3.14 / 180)
    ellObj.endAngle = 270 * (3.14 / 180)
    ZoomAll
    ' Find the start and endpoints for the ellipse
    startPoint = ellObj.startPoint
    endPoint = ellObj.endPoint
    MsgBox "This ellipse has a start point of " & _
           startPoint(0) & ", " & startPoint(1) & ", " & _
           startPoint(2) & " and an endpoint of " & _
           endPoint(0) & ", " & endPoint(1) & ", " & _
           endPoint(2), vbInformation, "StartPoint Example"
(defun c:Example_StartPoint()
    ;; This example creates an elliptical arc and then
    ;; finds the coordinates of its start and end points.
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    ;; Enter a start angle of 45 degrees, and an end angle of 270 degrees
    (vla-put-StartAngle ellObj (* 45 (/ 3.14 180)))
    (vla-put-EndAngle ellObj (* 270 (/ 3.14 180)))
    (vla-ZoomAll acadObj)
    ;; Find the start and endpoints for the ellipse
    (setq startPoint (vlax-safearray->list (vlax-variant-value (vla-get-StartPoint ellObj))))
    (setq endPoint (vlax-safearray->list (vlax-variant-value (vla-get-EndPoint ellObj))))
    (alert (strcat "This ellipse has a start point of " (rtos (nth 0 startPoint) 2) ", "
		                                        (rtos (nth 1 startPoint) 2) ", "
		                                        (rtos (nth 2 startPoint) 2) " and an endpoint of "
		                                        (rtos (nth 0 endPoint) 2) ", "
		                                        (rtos (nth 1 endPoint) 2) ", "
		                                        (rtos (nth 2 endPoint) 2)))
GMT+8, 2026-9-14 06:06
