SingleDocumentMode 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 803| 评论: 0|原作者: admin|来自: AutoCAD
确定AutoCAD是在单文档模式下运行还是在多文档模式下运行。
object.SingleDocumentMode
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用单绘模式。
  • False:禁用单绘模式。
此属性的初始值为 。False
此属性可帮助第三方开发人员更新应用程序,以便在 AutoCAD 多重图形模式下顺利工作。在AutoCAD的未来版本中,它可能会过时。
注意:此属性的值存储在 SDI 系统变量中。
Sub Example_SingleDocumentMode()
    ' This example reads and modifies the preference value that controls
    ' whether AutoCAD runs in single- or multiple-document mode.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSystem
    ' Get the system preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.System
    originalValue = ACADPref.SingleDocumentMode
    MsgBox "The SingleDocumentMode preference is set to: " & originalValue
    ' Modify the SingleDocumentMode preference by toggling the value
    ACADPref.SingleDocumentMode = Not (ACADPref.SingleDocumentMode)
    newValue = ACADPref.SingleDocumentMode
    MsgBox "The SingleDocumentMode preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.SingleDocumentMode = originalValue
    MsgBox "The SingleDocumentMode preference was reset back to: " & originalValue
(defun c:Example_SingleDocumentMode()
    ;; This example reads the preference value that lists
    ;; whether AutoCAD is running in single- or multiple-document mode.
    ;; Read the current value
    (setq currValue (vla-get-SingleDocumentMode (vla-get-System preferences)))
    (alert (strcat "The SingleDocumentMode preference is set to: " (if (= currValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:49
