ShowWarningMessages 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 591| 评论: 0|原作者: admin|来自: AutoCAD
重置所有具有“不再显示此警告”复选框的对话框,以便它们再次显示。
object.ShowWarningMessages
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:重置警告对话框。
  • False:不重置警告对话框。
此属性的初始值为 。False
Sub Example_ShowWarningMessages()
    ' This example reads and modifies the preference value that
    ' resets all dialog boxes that have the
    ' "Don't Display This Warning Again" check box so they display again.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSystem
    ' Get the system preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.System
    originalValue = ACADPref.ShowWarningMessages
    MsgBox "The ShowWarningMessages preference is set to: " & originalValue
    ' Modify the ShowWarningMessages preference by toggling the value
    ACADPref.ShowWarningMessages = Not (ACADPref.ShowWarningMessages)
    newValue = ACADPref.ShowWarningMessages
    MsgBox "The ShowWarningMessages preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.ShowWarningMessages = originalValue
    MsgBox "The ShowWarningMessages preference was reset back to: " & originalValue
(defun c:Example_ShowWarningMessages()
    ;; This example reads and modifies the preference value that
    ;; resets all dialog boxes that have the
    ;; "Don't Display This Warning Again" check box so they display again.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-ShowWarningMessages (vla-get-System preferences)))
    (alert (strcat "The ShowWarningMessages preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the ShowWarningMessages preference by toggling the value
    (vla-put-ShowWarningMessages (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The ShowWarningMessages preference has been set to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-ShowWarningMessages (vla-get-System preferences) originalValue)
    (alert (strcat "The ShowWarningMessages preference was reset back to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 11:12
