ShowProxyDialogBox 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 907| 评论: 0|原作者: admin|来自: AutoCAD
指定打开包含自定义对象的图形时 AutoCAD 是否显示警告消息。
object.ShowProxyDialogBox
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示警告。
  • False:不显示警告。
此属性的初始值为 。True
注意:此属性的值存储在 PROXYNOTICE 系统变量中。
Sub Example_ShowProxyDialogBox()
    ' ShowProxyDialogBox. It then changes the value, and finally
    Dim currShowProxyDialogBox As Boolean
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current ShowProxyDialogBox value
    currShowProxyDialogBox = preferences.OpenSave.ShowProxyDialogBox
    MsgBox "The current value for ShowProxyDialogBox is " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example"
    ' Change the value for ShowProxyDialogBox
    preferences.OpenSave.ShowProxyDialogBox = Not (currShowProxyDialogBox)
    MsgBox "The new value for ShowProxyDialogBox is " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example"
    ' Reset ShowProxyDialogBox to its original value
    preferences.OpenSave.ShowProxyDialogBox = currShowProxyDialogBox
    MsgBox "The ShowProxyDialogBox value is reset to " & preferences.OpenSave.ShowProxyDialogBox, vbInformation, "ShowProxyDialogBox Example"
(defun c:Example_ShowProxyDialogBox()
    ;; ShowProxyDialogBox. It then changes the value, and finally
    ;; Retrieve the current ShowProxyDialogBox value
    (setq currShowProxyDialogBox (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for ShowProxyDialogBox is " (if (= currShowProxyDialogBox :vlax-true) "True" "False")))
    ;; Change the value for ShowProxyDialogBox
    (vla-put-ShowProxyDialogBox (vla-get-OpenSave preferences) (if (= currShowProxyDialogBox :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for ShowProxyDialogBox is " (if (= (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
    ;; Reset ShowProxyDialogBox to its original value
    (vla-put-ShowProxyDialogBox (vla-get-OpenSave preferences) currShowProxyDialogBox)
    (alert (strcat "The ShowProxyDialogBox value is reset to " (if (= (vla-get-ShowProxyDialogBox (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-29 11:01
