ShowPlotStyles 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 802| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在图形中显示打印样式和打印样式名称。
object.ShowPlotStyles
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示和打印打印样式和打印样式名称。
  • False:不显示打印样式和打印样式名称。
该特性等同于 AutoCAD 中的“显示打印样式”选项。ShowPlotStyles
Sub Example_ShowPlotStyles()
    ' This example reads and modifies the ShowPlotStyles
    ' value, and then regenerates all viewports.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.ShowPlotStyles
    MsgBox "The ShowPlotStyles value is set to: " & originalValue
    ' Modify the ShowPlotStyles preference by changing the value
    ACADLayout.ShowPlotStyles = Not ACADLayout.ShowPlotStyles
    MsgBox "The ShowPlotStyles value has been set to: " & ACADLayout.ShowPlotStyles
    ' Regenerate viewports
(defun c:Example_ShowPlotStyles()
    ;; This example reads and modifies the ShowPlotStyles
    ;; value, and then regenerates all viewports.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-ShowPlotStyles ACADLayout))
    (alert (strcat "The ShowPlotStyles value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the ShowPlotStyles preference by changing the value
    (vla-put-ShowPlotStyles ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The ShowPlotStyles value has been set to: " (if (= (vla-get-ShowPlotStyles ACADLayout) :vlax-true) "True" "False")))
    ;; Regenerate viewports
GMT+8, 2026-11-25 15:28
