SelectionSets 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 662| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 SelectionSets 集合。
object.SelectionSets
类别: 文档
此属性应用于的对象。
只读:是的
类型:SelectionSets
图形的选择集集合。
Sub Example_SelectionSets()
    ' This example finds the current SelectionSets collection and
    ' adds a new SelectionSet to that collection.
    Dim SSetColl As AcadSelectionSets
    Set SSetColl = ThisDrawing.SelectionSets
    ' Create a SelectionSet named "TEST" in the current drawing
    Set ssetObj = SSetColl.Add("TEST")
    MsgBox "A new SelectionSet called " & ssetObj.name & " has been added to the SelectionSets collection.", vbInformation, "SelectionSets Example"
(defun c:Example_SelectionSets()
    ;; This example finds the current SelectionSets collection and
    ;; adds a new SelectionSet to that collection.
    (setq SSetColl (vla-get-SelectionSets doc))
    ;; Create a SelectionSet named "TEST" in the current drawing
    (setq ssetObj (vla-Add SSetColl "TEST"))
    (alert (strcat "A new SelectionSet called " (vla-get-Name ssetObj) " has been added to the SelectionSets collection."))
    (vla-Delete ssetObj)
GMT+8, 2026-11-30 10:57
