Selection 属性 (ActiveX)
获取 PreferencesSelection 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“选择”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesSelectionDatabasePreferences 例子VBA: Sub Example_Selection()
' This example obtains a reference to the Selection Preferences object
' from the Application Preferences object, and reads one of the Selection
' preferences
Dim ACADPref As AcadPreferencesSelection
' Obtain a reference to the Selection Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
MsgBox "We now have access to the properties and methods of the Selection Preferences object!"
MsgBox "The Selection preference GripSize is set to: " & ACADPref.GripSize
可视化 LISP: (vl-load-com)
(defun c:Example_Selection()
;; This example obtains a reference to the Selection Preferences object
;; from the Application Preferences object, and reads one of the Selection
;; preferences
(alert "We now have access to the properties and methods of the Selection Preferences object!")
(alert (strcat "The Selection preference GripSize is set to: " (itoa (vla-get-GripSize (vla-get-Selection preferences)))))
GMT+8, 2026-11-29 10:47
