SCMTimeMode 属性 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 851| 评论: 0|原作者: admin|来自: AutoCAD
控制对时间敏感的右键单击行为。
object.SCMTimeMode
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用时间敏感型右键单击。
  • False:禁用对时间敏感的右键单击。
此属性用于设置对时间敏感的右键单击行为。快速单击与按 Enter 键相同。较长的单击将显示快捷菜单。仅当该属性设置为 时,才能设置此属性。ShortcutMenuDisplayTrue
您可以使用该属性设置右键单击的持续时间。SCMTimeValue
注意:此属性的值存储在 SHORTCUTMENUDURATION 系统变量中。
Sub Example_SCMTimeMode()
    ' This example reads and modifies the SCMTimeMode property.
    ' Then the property is reset to its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Boolean, newValue As Boolean
    ' Get the UserPreferences object
    Set ACADPref = ThisDrawing.Application.Preferences.User
    originalValue = ACADPref.SCMTimeMode
    MsgBox "The SCMTimeMode property is currently: " & originalValue
    newValue = IIf(originalValue, False, True)
    ACADPref.SCMTimeMode = newValue
    MsgBox "The SCMTimeMode property has been set to: " & ACADPref.SCMTimeMode
    ACADPref.SCMTimeMode = originalValue
    MsgBox "The SCMTimeMode property was reset back to: " & originalValue
(defun c:Example_SCMTimeMode()
    ;; This example reads and modifies the SCMTimeMode property.
    ;; Then the property is reset to its original value.
    (setq originalValue (vla-get-SCMTimeMode (vla-get-User preferences)))
    (alert (strcat "The SCMTimeMode property is currently: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the SCMTimeMode preference by toggling the value
    (setq newValue (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (vla-put-SCMTimeMode (vla-get-User preferences) newValue)
    (alert (strcat "The SCMTimeMode property has been set to: " (if (= newValue :vlax-true) "True" "False")))
    (vla-put-SCMTimeMode (vla-get-User preferences) originalValue)
    (alert (strcat "The SCMTimeMode property was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:47
