Scale 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 739| 评论: 0|原作者: admin|来自: AutoCAD
Scale 属性 (ActiveX)
指定从扫描路径的起点到终点的比例因子。
object.Scale
类型:PointCloud、PointCloudEx、SweptSurface
此属性应用于的对象。
只读:不
类型:双
应用于对象或扫描路径的比例因子。
Sub SurfaceProperties()
    Set ssetObj = ThisDrawing.SelectionSets.Add("SURFACES2")
    Dim mode As Integer
    ssetObj.SelectOnScreen
    Dim obj As AcadEntity
    Dim extrude As AcadExtrudedSurface
    Dim objName As String
    Dim LayerName As String
    For Each obj In ssetObj
        objName = obj.ObjectName
        If TypeOf obj Is AcadExtrudedSurface Then
            ExtrudedSurfaceProperties obj
        ElseIf TypeOf obj Is AcadRevolvedSurface Then
            RevolvedSurfaceProperties obj
        ElseIf TypeOf obj Is AcadLoftedSurface Then
            LoftedSurfaceProperties obj
        ElseIf TypeOf obj Is AcadSweptSurface Then
            SweptSurfaceProperties obj
        ElseIf TypeOf obj Is AcadPlaneSurface Then
            PlaneSurfaceProperties obj
        End If
    Next
    ssetObj.Delete
Private Sub ExtrudedSurfaceProperties(extrude As AcadExtrudedSurface)
    GetSurfaceBoundingBox extrude
    MsgBox "SurfaceType: " & extrude.SurfaceType & vbCr & _
           "Height: " & extrude.height & vbCr & _
           "TaperAngle: " & extrude.TaperAngle & vbCr & _
           "Direction: " & extrude.Direction & vbCr & _
           "Material: " & extrude.Material & vbCr & _
           "UIsolineDensity: " & extrude.UIsolineDensity & vbCr & _
           "VIsolineDensity: " & extrude.VIsolineDensity
    'Now change the configurable properties
    extrude.height = extrude.height * 1.5
    extrude.TaperAngle = extrude.TaperAngle * (3.14 / 2)
    extrude.UIsolineDensity = extrude.UIsolineDensity * 2#
    extrude.VIsolineDensity = extrude.VIsolineDensity * 0.5
    ThisDrawing.Regen acActiveViewport
    Utility.GetString 0, "Press return to continue..."
    'Now change the properties back to their original values
    extrude.height = extrude.height / 1.5
    extrude.TaperAngle = extrude.TaperAngle / (3.14 / 2)
    extrude.UIsolineDensity = extrude.UIsolineDensity / 2#
    extrude.VIsolineDensity = extrude.VIsolineDensity / 0.5
Private Sub RevolvedSurfaceProperties(revolve As AcadRevolvedSurface)
    GetSurfaceBoundingBox revolve
    MsgBox "SurfaceType: " & revolve.SurfaceType & vbCr & _
           "RevolutionAngle: " & revolve.RevolutionAngle & vbCr & _
           "AxisPosition: " & revolve.AxisPosition & vbCr & _
           "AxisDirection: " & revolve.AxisDirection & vbCr & _
           "Material: " & revolve.Material & vbCr & _
           "UIsolineDensity: " & revolve.UIsolineDensity & vbCr & _
           "VIsolineDensity: " & revolve.VIsolineDensity
    revolve.RevolutionAngle = revolve.RevolutionAngle * (3.14 / 2)
    revolve.UIsolineDensity = revolve.UIsolineDensity * 2#
    revolve.VIsolineDensity = revolve.VIsolineDensity * 0.5
    revolve.RevolutionAngle = revolve.RevolutionAngle / (3.14 / 2)
    revolve.UIsolineDensity = revolve.UIsolineDensity / 2#
    revolve.VIsolineDensity = revolve.VIsolineDensity / 0.5
Private Sub LoftedSurfaceProperties(lofted As AcadLoftedSurface)
    GetSurfaceBoundingBox lofted
    MsgBox "SurfaceType: " & lofted.SurfaceType & vbCr & _
           "NumCrossSections: " & lofted.NumCrossSections & vbCr & _
           "NumGuidePaths: " & lofted.NumGuidePaths & vbCr & _
           "SurfaceNormals: " & lofted.SurfaceNormals & vbCr & _
           "StartDraftAngle: " & lofted.StartDraftAngle & vbCr & _
           "StartDraftMagnitude: " & lofted.StartDraftMagnitude & vbCr & _
           "EndDraftAngle: " & lofted.EndDraftAngle & vbCr & _
           "EndDraftMagnitude: " & lofted.EndDraftMagnitude & vbCr & _
           "Closed: " & lofted.Closed & vbCr & _
           "Material: " & lofted.Material & vbCr & _
           "UIsolineDensity: " & lofted.UIsolineDensity & vbCr & _
           "VIsolineDensity: " & lofted.VIsolineDensity
    lofted.StartDraftAngle = lofted.StartDraftAngle * (3.14 / 2)
    lofted.EndDraftAngle = lofted.EndDraftAngle * (3.14 / 4)
    lofted.UIsolineDensity = lofted.UIsolineDensity * 2#
    lofted.VIsolineDensity = lofted.VIsolineDensity * 0.5
    lofted.StartDraftAngle = lofted.StartDraftAngle / (3.14 / 2)
    lofted.EndDraftAngle = lofted.EndDraftAngle / (3.14 / 4)
    lofted.UIsolineDensity = lofted.UIsolineDensity / 2#
    lofted.VIsolineDensity = lofted.VIsolineDensity / 0.5
Private Sub SweptSurfaceProperties(swept As AcadSweptSurface)
    GetSurfaceBoundingBox swept
    MsgBox "SurfaceType: " & swept.SurfaceType & vbCr & _
           "ProfileRotation: " & swept.ProfileRotation & vbCr & _
           "Bank: " & swept.Bank & vbCr & _
           "Twist: " & swept.Twist & vbCr & _
           "scale: " & swept.scale & vbCr & _
           "Length: " & swept.length & vbCr & _
           "Material: " & swept.Material & vbCr & _
           "UIsolineDensity: " & swept.UIsolineDensity & vbCr & _
           "VIsolineDensity: " & swept.VIsolineDensity
    swept.ProfileRotation = swept.ProfileRotation * 3.14 * 0.25
    swept.Bank = Not swept.Bank
    swept.Twist = swept.Twist * 3.14 * -0.5
    swept.UIsolineDensity = swept.UIsolineDensity * 2#
    swept.VIsolineDensity = swept.VIsolineDensity * 0.5
    swept.ProfileRotation = swept.ProfileRotation / (3.14 * 0.25)
    swept.Twist = swept.Twist / (3.14 * -0.5)
    swept.UIsolineDensity = swept.UIsolineDensity / 2#
    swept.VIsolineDensity = swept.VIsolineDensity / 0.5
Private Sub PlaneSurfaceProperties(planar As AcadPlaneSurface)
    GetSurfaceBoundingBox planar
    MsgBox "SurfaceType: " & planar.SurfaceType & vbCr & _
           "UIsolineDensity: " & planar.UIsolineDensity & vbCr & _
           "VIsolineDensity: " & planar.VIsolineDensity
    planar.UIsolineDensity = planar.UIsolineDensity * 2#
    planar.VIsolineDensity = planar.VIsolineDensity * 0.5
    planar.UIsolineDensity = planar.UIsolineDensity / 2#
    planar.VIsolineDensity = planar.VIsolineDensity / 0.5
Private Sub GetSurfaceBoundingBox(surf As AcadSurface)
    Dim MinPoint As Variant
    Dim MaxPoint As Variant
    surf.GetBoundingBox MinPoint, MaxPoint
    ' Print the min and max extents
    MsgBox "The extents of the bounding box for the surface are:" & vbCrLf _
           & "Min Point: " & MinPoint(0) & "," & MinPoint(1) & "," & MinPoint(2) _
           & vbCrLf & "Max Point: " & MaxPoint(0) & "," & MaxPoint(1) & "," & MaxPoint(2), vbInformation, "GetBoundingBox of Surface"
(defun c:SurfaceProperties()
    (setq ssetObj (vla-Add (vla-get-SelectionSets doc) "SURFACES2"))
    (vla-SelectOnScreen ssetObj)
    (vlax-for obj ssetObj
        (setq objName (vla-get-ObjectName obj))
        (cond
          ((= "AcDb3dSolid" objName)
            (cond
                ((= (vla-get-SolidType obj) "Extrusion") (alert "Extruded solid selected."))
                ((= (vla-get-SolidType obj) "Revolve") (alert "Revolved solid selected."))
                ((= (substr (vla-get-SolidType obj) 1 4) "Loft") (alert "Lofted solid selected."))
                ((= (vla-get-SolidType obj) "Sweep") (alert "Swept solid selected."))
          ((= "AcDbExtrudedSurface" objName) (ExtrudedSurfaceProperties obj))
          ((= "AcDbRevolvedSurface" objName) (RevolvedSurfaceProperties obj))
          ((= "AcDbLoftedSurface" objName) (LoftedSurfaceProperties obj))
          ((= "AcDbSweptSurface" objName) (SweptSurfaceProperties obj))
          ((= "AcDbPlaneSurface" objName) (PlaneSurfaceProperties obj))
    (vla-Delete ssetObj)
(defun ExtrudedSurfaceProperties (extrude / )
    (GetSurfaceBoundingBox extrude)
    (alert (strcat "SurfaceType: " (vla-get-SurfaceType extrude)
                   "\nHeight: " (rtos (vla-get-Height extrude) 2)
                   "\nTaperAngle: " (rtos (vla-get-TaperAngle extrude) 2)
                   "\nMaterial: " (vla-get-Material extrude)
                   "\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity extrude))
                   "\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity extrude))))
    ;; Now change the configurable properties
    (vla-put-Height extrude (* (vla-get-Height extrude) 1.5))
    (vla-put-TaperAngle extrude (* (vla-get-TaperAngle extrude) (/ 3.14 2)))
    (vla-put-UIsolineDensity extrude (* (vla-get-UIsolineDensity extrude) 2))
    (vla-put-VIsolineDensity extrude (* (vla-get-VIsolineDensity extrude) 0.5))
    (vla-Regen doc acActiveViewport)
    (vla-GetString (vla-get-Utility doc) 0 "Press return to continue...")
    ;; Now change the properties back to their original values
    (vla-put-Height extrude (/ (vla-get-Height extrude) 1.5))
    (vla-put-TaperAngle extrude (/ (vla-get-TaperAngle extrude) (/ 3.14 2)))
    (vla-put-UIsolineDensity extrude (/ (vla-get-UIsolineDensity extrude) 2))
    (vla-put-VIsolineDensity extrude (/ (vla-get-VIsolineDensity extrude) 0.5))
(defun RevolvedSurfaceProperties (revolve / )
    (GetSurfaceBoundingBox revolve)
    (alert (strcat "SurfaceType: " (vla-get-SurfaceType revolve)
                   "\nRevolutionAngle: " (rtos (vla-get-RevolutionAngle revolve) 2)
                   "\nMaterial: " (vla-get-Material revolve)
                   "\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity revolve))
                   "\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity revolve))))
    (vla-put-RevolutionAngle revolve (* (vla-get-RevolutionAngle revolve) (/ 3.14 2)))
    (vla-put-UIsolineDensity revolve (* (vla-get-UIsolineDensity revolve) 2))
    (vla-put-VIsolineDensity revolve (* (vla-get-VIsolineDensity revolve) 0.5))
    (vla-put-RevolutionAngle revolve (/ (vla-get-RevolutionAngle revolve) (/ 3.14 2)))
    (vla-put-UIsolineDensity revolve (/ (vla-get-UIsolineDensity revolve) 2))
    (vla-put-VIsolineDensity revolve (/ (vla-get-VIsolineDensity revolve) 0.5))
(defun LoftedSurfaceProperties (lofted / )
    (GetSurfaceBoundingBox lofted)
    (alert (strcat "SurfaceType: " (vla-get-SurfaceType lofted)
                   "\nNumCrossSections: " (itoa (vla-get-NumCrossSections lofted))
                   "\nNumGuidePaths: " (itoa (vla-get-NumGuidePaths lofted))
                   "\nSurfaceNormals: " (itoa (vla-get-SurfaceNormals lofted))
                   "\nStartDraftAngle: " (rtos (vla-get-StartDraftAngle lofted) 2)
                   "\nStartDraftMagnitude: " (rtos (vla-get-StartDraftMagnitude lofted) 2)
                   "\nEndDraftAngle: " (rtos (vla-get-EndDraftAngle lofted) 2)
                   "\nEndDraftMagnitude: " (rtos (vla-get-EndDraftMagnitude lofted) 2)
                   "\nClosed: " (if (= (vla-get-Closed lofted) :vlax-true) "True" "False")
                   "\nMaterial: " (vla-get-Material lofted)
                   "\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity lofted))
                   "\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity lofted))))
    (vla-put-StartDraftAngle lofted (* (vla-get-StartDraftAngle lofted) (/ 3.14 2)))
    (vla-put-EndDraftAngle lofted (* (vla-get-EndDraftAngle lofted) (/ 3.14 4)))
    (vla-put-UIsolineDensity lofted (* (vla-get-UIsolineDensity lofted) 2))
    (vla-put-VIsolineDensity lofted (* (vla-get-VIsolineDensity lofted) 0.5))
    (vla-put-StartDraftAngle lofted (/ (vla-get-StartDraftAngle lofted) (/ 3.14 2)))
    (vla-put-EndDraftAngle lofted (/ (vla-get-EndDraftAngle lofted) (/ 3.14 4)))
    (vla-put-UIsolineDensity lofted (/ (vla-get-UIsolineDensity lofted) 2))
    (vla-put-VIsolineDensity lofted (/ (vla-get-VIsolineDensity lofted) 0.5))
(defun SweptSurfaceProperties (swept / )
    (GetSurfaceBoundingBox swept)
    (alert (strcat "SurfaceType: " (vla-get-SurfaceType swept)
                   "\nProfileRotation: " (rtos (vla-get-ProfileRotation swept) 2)
                   "\nBank: " (if (= (vla-get-Bank swept) :vlax-true) "True" "False")
                   "\nTwist: " (rtos (vla-get-Twist swept) 2)
                   "\nscale: " (rtos (vla-get-Scale swept) 2)
                   "\nLength: " (rtos (vla-get-Length swept) 2)
                   "\nMaterial: " (vla-get-Material swept)
                   "\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity swept))
                   "\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity swept))))
    (vla-put-ProfileRotation swept (* (vla-get-ProfileRotation swept) (* 3.14 0.25)))
    (vla-put-Bank swept (if (= (vla-get-Bank swept) :vlax-true) :vlax-false :vlax-true))
    (vla-put-Twist swept (* (vla-get-Twist swept) (* 3.14 -0.5)))
    (vla-put-UIsolineDensity swept (* (vla-get-UIsolineDensity swept) 2))
    (vla-put-VIsolineDensity swept (* (vla-get-VIsolineDensity swept) 0.5))
    (vla-put-ProfileRotation swept (/ (vla-get-ProfileRotation swept) (* 3.14 0.25)))
    (vla-put-Twist swept (/ (vla-get-Twist swept) (* 3.14 -0.5)))
    (vla-put-UIsolineDensity swept (/ (vla-get-UIsolineDensity swept) 2))
    (vla-put-VIsolineDensity swept (/ (vla-get-VIsolineDensity swept) 0.5))
(defun PlaneSurfaceProperties (planar / )
    (GetSurfaceBoundingBox planar)
    (alert (strcat "SurfaceType: " (vla-get-SurfaceType planar)
                   "\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity planar))
                   "\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity planar))))
    (vla-put-UIsolineDensity planar (* (vla-get-UIsolineDensity planar) 2))
    (vla-put-VIsolineDensity planar (* (vla-get-VIsolineDensity planar) 0.5))
    (vla-put-UIsolineDensity planar (/ (vla-get-UIsolineDensity planar) 2))
    (vla-put-VIsolineDensity planar (/ (vla-get-VIsolineDensity planar) 0.5))
(defun GetSurfaceBoundingBox (surf / )
    (vla-GetBoundingBox surf 'MinPoint 'MaxPoint)
    ;; Print the min and max extents
    (alert (strcat "The extents of the bounding box for the surface are:"
                   "\nMin Point: " (rtos (vlax-safearray-get-element MinPoint 0) 2) ","
                                   (rtos (vlax-safearray-get-element MinPoint 1) 2) ","
                                   (rtos (vlax-safearray-get-element MinPoint 2) 2)
                   "\nMax Point: " (rtos (vlax-safearray-get-element MaxPoint 0) 2) ","
                                   (rtos (vlax-safearray-get-element MaxPoint 1) 2) ","
                                   (rtos (vlax-safearray-get-element MaxPoint 2) 2)))
GMT+8, 2026-10-17 20:58
