SaveAsType 属性 (ActiveX)
指定用于保存图形的图形类型。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acSaveAsType
言论此属性的初始值为 。以下值已过时:ac2013_dwg
例子VBA: Sub Example_SaveAsType()
' This example reads and modifies the preference value that controls
' the drawing type to save the drawing as.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOpenSave
Dim originalValue As Variant, DisplayValue As String
' Get the OpenSave preferences object
Set ACADPref = ThisDrawing.Application.Preferences.OpenSave
' Store current setting
originalValue = ACADPref.SaveAsType
GoSub GETVALUE
MsgBox "The SaveAsType preference is: " & DisplayValue
' Modify the SaveAsType preference by changing it to AutoCAD 2000 DWG
ACADPref.SaveAsType = ac2000_dwg
GoSub GETVALUE
MsgBox "The SaveAsType preference has been set to: " & DisplayValue
' Comment out this last section to leave the change to
' the preference in effect
ACADPref.SaveAsType = originalValue
GoSub GETVALUE
MsgBox "The SaveAsType preference was reset back to: " & DisplayValue
Exit Sub
GETVALUE:
' Convert the value of this setting to a meaningful text string
DisplayValue = ACADPref.SaveAsType
Select Case DisplayValue
Case ac2000_dwg: DisplayValue = "AutoCAD 2000 DWG (*.dwg)"
Case acR15_dwg: DisplayValue = "AutoCAD 2000 DWG (*.dwg)"
Case ac2000_dxf: DisplayValue = "AutoCAD 2000 DXF (*.dxf)"
Case acR15_dxf: DisplayValue = "AutoCAD 2000 DXF (*.dxf)"
Case ac2000_Template: DisplayValue = "AutoCAD 2000 Drawing Template File (*.dwt)"
Case ac2004_dwg: DisplayValue = "AutoCAD 2004 DWG (*.dwg)"
Case acR18_dwg: DisplayValue = "AutoCAD 2004 DWG (*.dwg)"
Case ac2004_dxf: DisplayValue = "AutoCAD 2004 DXF (*.dxf)"
Case acR18_dxf: DisplayValue = "AutoCAD 2004 DXF (*.dxf)"
Case ac2004_Template: DisplayValue = "AutoCAD 2004 Drawing Template File (*.dwt)"
Case ac2007_dwg: DisplayValue = "AutoCAD 2007 DWG (*.dwg)"
Case ac2007_dxf: DisplayValue = "AutoCAD 2007 DXF (*.dxf)"
Case ac2007_Template: DisplayValue = "AutoCAD 2007 Drawing Template File (*.dwt)"
Case ac2010_dwg: DisplayValue = "AutoCAD 2010 DWG (*.dwg)"
Case ac2010_dxf: DisplayValue = "AutoCAD 2010 DXF (*.dxf)"
Case ac2010_Template: DisplayValue = "AutoCAD 2010 Drawing Template File (*.dwt)"
Case ac2013_dwg: DisplayValue = "AutoCAD 2013 DWG (*.dwg)"
Case ac2013_dxf: DisplayValue = "AutoCAD 2013 DXF (*.dxf)"
Case ac2013_Template: DisplayValue = "AutoCAD 2013 Drawing Template File (*.dwt)"
Case ac2018_dwg: DisplayValue = "AutoCAD 2018 DWG (*.dwg)"
Case ac2018_dxf: DisplayValue = "AutoCAD 2018 DXF (*.dxf)"
Case ac2018_Template: DisplayValue = "AutoCAD 2018 Drawing Template File (*.dwt)"
Case acR12_dxf: DisplayValue = "AutoCAD R12 DXF (*.dxf)"
Case acR13_dwg: DisplayValue = "AutoCAD R13 DWG (*.dwg)"
Case acR13_dxf: DisplayValue = "AutoCAD R13 DXF (*.dxf)"
Case acR14_dwg: DisplayValue = "AutoCAD R14 DWG (*.dwg)"
Case acR14_dxf: DisplayValue = "AutoCAD R14 DXF (*.dxf)"
Case acNative: DisplayValue = "Latest drawing release"
Case acUnknown: DisplayValue = "The drawing type is unknown"
End Select
Return
可视化 LISP: (defun c:Example_SaveAsType()
;; This example reads and modifies the preference value that controls
;; the drawing type to save the drawing as.
;; When finished, this example resets the preference value back to
;; its original value.
;; Store current setting
(setq originalValue (vla-get-SaveAsType (vla-get-OpenSave preferences)))
(setq DisplayValue (SaveAsTypeMsg (vla-get-SaveAsType (vla-get-OpenSave preferences))))
(alert (strcat "The SaveAsType preference is: " DisplayValue))
;; Modify the SaveAsType preference by changing it to AutoCAD 2000 DWG
(vla-put-SaveAsType (vla-get-OpenSave preferences) ac2000_dwg)
(alert (strcat "The SaveAsType preference has been set to: " DisplayValue))
;; Comment out this last section to leave the change to
;; the preference in effect
(vla-put-SaveAsType (vla-get-OpenSave preferences) originalValue)
(alert (strcat "The SaveAsType preference was reset back to: " DisplayValue))
(defun SaveAsTypeMsg (DisplayValue / )
;; Convert the value of this setting to a meaningful text string
(cond
((or (= DisplayValue ac2000_dwg)
(= DisplayValue acR15_dwg)) (setq DisplayValue "AutoCAD 2000 DWG (*.dwg)"))
((or (= DisplayValue ac2000_dxf)
(= DisplayValue acR15_dxf)) (setq DisplayValue "AutoCAD 2000 DXF (*.dxf)"))
((= DisplayValue ac2000_Template) (setq DisplayValue "AutoCAD 2000 Drawing Template File (*.dwt)"))
((or (= DisplayValue ac2004_dwg)
(= DisplayValue acR18_dwg)) (setq DisplayValue "AutoCAD 2004 DWG (*.dwg)"))
((or (= DisplayValue ac2004_dxf)
(= DisplayValue acR18_dxf)) (setq DisplayValue "AutoCAD 2004 DXF (*.dxf)"))
((= DisplayValue ac2004_Template) (setq DisplayValue "AutoCAD 2004 Drawing Template File (*.dwt)"))
((= DisplayValue ac2007_dwg) (setq DisplayValue "AutoCAD 2007 DWG (*.dwg)"))
((= DisplayValue ac2007_dxf) (setq DisplayValue "AutoCAD 2007 DXF (*.dxf)"))
((= DisplayValue ac2007_Template) (setq DisplayValue "AutoCAD 2007 Drawing Template File (*.dwt)"))
((= DisplayValue ac2010_dwg) (setq DisplayValue "AutoCAD 2010 DWG (*.dwg)"))
((= DisplayValue ac2010_dxf) (setq DisplayValue "AutoCAD 2010 DXF (*.dxf)"))
((= DisplayValue ac2010_Template) (setq DisplayValue "AutoCAD 2010 Drawing Template File (*.dwt)"))
((= DisplayValue ac2013_dwg) (setq DisplayValue "AutoCAD 2013 DWG (*.dwg)"))
((= DisplayValue ac2013_dxf) (setq DisplayValue "AutoCAD 2013 DXF (*.dxf)"))
((= DisplayValue ac2013_Template) (setq DisplayValue "AutoCAD 2013 Drawing Template File (*.dwt)"))
((= DisplayValue ac2018_dwg) (setq DisplayValue "AutoCAD 2018 DWG (*.dwg)"))
((= DisplayValue ac2018_dxf) (setq DisplayValue "AutoCAD 2018 DXF (*.dxf)"))
((= DisplayValue ac2018_Template) (setq DisplayValue "AutoCAD 2018 Drawing Template File (*.dwt)"))
((= DisplayValue acR12_dxf) (setq DisplayValue "AutoCAD R12 DXF (*.dxf)"))
((= DisplayValue acR13_dwg) (setq DisplayValue "AutoCAD R13 DWG (*.dwg)"))
((= DisplayValue acR13_dxf) (setq DisplayValue "AutoCAD R13 DXF (*.dxf)"))
((= DisplayValue acR14_dwg) (setq DisplayValue "AutoCAD R14 DWG (*.dwg)"))
((= DisplayValue acR14_dxf) (setq DisplayValue "AutoCAD R14 DXF (*.dxf)"))
((= DisplayValue acNative) (setq DisplayValue "Latest drawing release"))
((= DisplayValue acUnknown) (setq DisplayValue "The drawing type is unknown"))
DisplayValue
GMT+8, 2026-10-17 22:28
