Rows 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 687| 评论: 0|原作者: admin|来自: AutoCAD
Rows 属性 (ActiveX)
指定块数组或表中的行数。
object.Rows
类型:MInsertBlock、Table
此属性应用于的对象。
只读:不
类型:长
块数组或表中的行数。
Sub Example_Rows()
    ' This example creates a new MInsertBlock in the current drawing and
    ' displays the column and row information for the new MInsertBlock
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double, InsertPoint(0 To 2) As Double
    Dim radius As Double
    Dim newMBlock As AcadMInsertBlock
    Dim newBlock As AcadBlock
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
    radius = 0.5
    ' Create a new block to hold the Circle
    Set newBlock = ThisDrawing.Blocks.Add(centerPoint, "CBlock")
    ' Add the Circle object to the new block
    Set circleObj = ThisDrawing.Blocks("CBlock").AddCircle(centerPoint, radius)
    ' Create a rectangular array of Circles using the new block containing the Circle
    ' and the AddMInsertBlock method
    Set newMBlock = ThisDrawing.ModelSpace.AddMInsertBlock(InsertPoint, "CBlock", 1, 1, 1, 1, 2, 2, 1, 1)
    ' Display information about the Columns and Rows defined by the MInsertBlock
    MsgBox "The new rectangular array is comprised of: " & vbCrLf & _
            newMBlock.Columns & " columns with a spacing of " & newMBlock.ColumnSpacing & " and" & vbCrLf & _
            newMBlock.Rows & " rows with a spacing of " & newMBlock.RowSpacing
(defun c:Example_Rows()
    ;; This example creates a new MInsertBlock in the current drawing and
    ;; displays the column and row information for the new MInsertBlock
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          InsertPoint (vlax-3d-point 1 1 0)
          radius 0.5)
    ;; Create a new block to hold the Circle
    (setq newBlock (vla-Add (vla-get-Blocks doc) centerPoint "CBlock"))
    ;; Add the Circle object to the new block
    (setq circleObj (vla-AddCircle newBlock centerPoint radius))
    ;; Create a rectangular array of Circles using the new block containing the Circle
    ;; and the AddMInsertBlock method
    (setq newMBlock (vla-AddMInsertBlock modelSpace InsertPoint "CBlock" 1 1 1 1 2 2 1 1))
    (vla-ZoomAll acadObj)
    ;; Display information about the Columns and Rows defined by the MInsertBlock
    (alert (strcat "The new rectangular array comprises: \n"
                   (itoa (vla-get-Columns newMBlock)) " columns with a spacing of " (rtos (vla-get-ColumnSpacing newMBlock) 2) " and\n"
                   (itoa (vla-get-Rows newMBlock)) " rows with a spacing of " (rtos (vla-get-RowSpacing newMBlock) 2) "."))
GMT+8, 2026-10-17 21:38
