ReadOnly 属性 (ActiveX)
指定文档或属性是只读的还是读写的。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_ReadOnly()
' This example shows if current drawing file is read only or not
If ThisDrawing.ReadOnly Then
MsgBox "The current drawing file is read only.", , "ReadOnly Example"
Else
MsgBox "The current drawing file is read-write.", , "ReadOnly Example"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_ReadOnly()
;; This example shows if current drawing file is read only or not
(if (= (vla-get-ReadOnly doc) :vlax-true)
(alert "The current drawing file is read only.")
(alert "The current drawing file is read-write.")
GMT+8, 2026-11-30 12:09
