PrintSpoolExecutable 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 741| 评论: 0|原作者: admin|来自: AutoCAD
指定要用于打印后台处理的应用程序。
object.PrintSpoolExecutable
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
打印后台打印应用程序。
此属性包含用于 AutoSpool 的打印后台处理可执行文件的驱动器、路径和应用程序名称。
Sub Example_PrintSpoolExecutable()
    ' PrintSpoolExecutable. It then changes the value, and finally
    Dim currPrintSpoolExecutable As String
    Dim newPrintSpoolExecutable As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current PrintSpoolExecutable value
    currPrintSpoolExecutable = preferences.Files.PrintSpoolExecutable
    MsgBox "The current value for PrintSpoolExecutable is " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
    ' Change the value for PrintSpoolExecutable
    newPrintSpoolExecutable = "TestPrintSpoolExecutable"
    preferences.Files.PrintSpoolExecutable = newPrintSpoolExecutable
    MsgBox "The new value for PrintSpoolExecutable is " & newPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
    ' Reset PrintSpoolExecutable to its original value
    preferences.Files.PrintSpoolExecutable = currPrintSpoolExecutable
    MsgBox "The PrintSpoolExecutable value is reset to " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
(defun c:Example_PrintSpoolExecutable()
    ;; PrintSpoolExecutable. It then changes the value, and finally
    ;; Retrieve the current PrintSpoolExecutable value
    (setq currPrintSpoolExecutable (vla-get-PrintSpoolExecutable (vla-get-Files preferences)))
    (alert (strcat "The current value for PrintSpoolExecutable is " currPrintSpoolExecutable))
    ;; Change the value for PrintSpoolExecutable
    (setq newPrintSpoolExecutable "TestPrintSpoolExecutable")
    (vla-put-PrintSpoolExecutable (vla-get-Files preferences) newPrintSpoolExecutable)
    (alert (strcat "The new value for PrintSpoolExecutable is " newPrintSpoolExecutable))
    ;; Reset PrintSpoolExecutable to its original value
    (vla-put-PrintSpoolExecutable (vla-get-Files preferences) currPrintSpoolExecutable)
    (alert (strcat "The PrintSpoolExecutable value is reset to " currPrintSpoolExecutable))
GMT+8, 2026-10-28 09:02
