PlotWithLineweights 属性 (ActiveX)
指定对象是使用打印文件中指定的线宽进行打印,还是使用图形文件中的线宽进行打印。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_PlotWithLineweights()
' This example reads and modifies the PlotWithLineweights
' Layout value.
' When finished, this example resets the value back to
' its original value.
Dim ACADLayout As ACADLayout
Dim originalValue As Boolean
' Get the layout object
Set ACADLayout = ThisDrawing.ActiveLayout
originalValue = ACADLayout.PlotWithLineweights
MsgBox "The PlotWithLineweights value is set to: " & originalValue
' Modify the PlotWithLineweights preference by toggling the value
ACADLayout.PlotWithLineweights = Not ACADLayout.PlotWithLineweights
MsgBox "The PlotWithLineweights preference has been set to: " & ACADLayout.PlotWithLineweights
ACADLayout.PlotWithLineweights = originalValue
MsgBox "The PlotWithLineweights preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PlotWithLineweights()
;; This example reads and modifies the PlotWithLineweights
;; Layout value.
;; When finished, this example resets the value back to
;; its original value.
;; Get the layout object
(setq ACADLayout (vla-get-ActiveLayout doc))
(setq originalValue (vla-get-PlotWithLineweights ACADLayout))
(alert (strcat "The PlotWithLineweights value is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PlotWithLineweights preference by toggling the value
(vla-put-PlotWithLineweights ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-PlotWithLineweights ACADLayout))
(alert (strcat "The PlotWithLineweights preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
(vla-put-PlotWithLineweights ACADLayout originalValue)
(alert (strcat "The PlotWithLineweights preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:47
