PickFirst 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 563| 评论: 0|原作者: admin|来自: AutoCAD
确定是在发出命令之前(名词-动词选择)之前还是之后选择对象。
object.PickFirst
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:打开 PICKFIRST。
  • False:关闭 PICKFIRST。
此属性的初始值为 。True
注意:此属性的值存储在 PICKFIRST 系统变量中。
Sub Example_PickFirst()
    ' This example reads and modifies the preference value that controls
    ' whether you select objects before (noun-verb selection) or after
    ' you issue a command.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickFirst
    MsgBox "The PickFirst preference is set to: " & originalValue
    ' Modify the PickFirst preference by toggling the value
    ACADPref.PickFirst = Not (ACADPref.PickFirst)
    newValue = ACADPref.PickFirst
    MsgBox "The PickFirst preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickFirst = originalValue
    MsgBox "The PickFirst preference was reset back to: " & originalValue
(defun c:Example_PickFirst()
    ;; This example reads and modifies the preference value that controls
    ;; whether you select objects before (noun-verb selection) or after
    ;; you issue a command.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickFirst (vla-get-Selection preferences)))
    (alert (strcat "The PickFirst preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PickFirst preference by toggling the value
    (vla-put-PickFirst (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PickFirst (vla-get-Selection preferences)))
    (alert (strcat "The PickFirst preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PickFirst (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickFirst preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 13:01
