Output 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 752| 评论: 0|原作者: admin|来自: AutoCAD
Output 属性 (ActiveX)
获取 PreferencesOutput 对象。
object.Output
类型:首选项
此属性应用于的对象。
只读:是的
类型:首选项输出
获取对象。PreferencesOutput
该对象保存存储在注册表中的“选项”对话框的“输出”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOutputDatabasePreferences
Sub Example_Output()
    ' This example obtains a reference to the Output Preferences object
    ' from the Application Preferences object, and reads one of the Output
    ' preferences
    Dim ACADPref As AcadPreferencesOutput
    ' Obtain a reference to the Output Preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    MsgBox "You now have access to the properties and methods of the Output Preferences object!"
    MsgBox "The Output preference DefaultOutputDevice is set to: " & ACADPref.DefaultOutputDevice
(defun c:Example_Output()
    ;; This example obtains a reference to the Output Preferences object
    ;; from the Application Preferences object, and reads one of the Output
    ;; preferences
    ;; Obtain a reference to the Output Preferences object
    (alert (strcat "You now have access to the properties and methods of the Output Preferences object!"
                   "\nThe Output preference DefaultOutputDevice is set to: " (vla-get-DefaultOutputDevice (vla-get-Output preferences))))
GMT+8, 2026-10-17 21:38
