OnMenuBar 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 656| 评论: 0|原作者: admin|来自: AutoCAD
确定指定的弹出菜单是否位于菜单栏上。
object.OnMenuBar
类型:PopupMenu
此属性应用于的对象。
只读:是的
类型:布尔
  • True:此菜单位于菜单栏上。
  • False:此菜单不在菜单栏上。
Sub Example_OnMenuBar()
    ' This example creates a new menu called TestMenu and inserts a menu item
    ' into it. The menu is then displayed on the menu bar, and then
    ' removed from the menu bar.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("TestMenu")
    ' Add a menu item to the new menu
    Dim newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
    ' Display the menu on the menu bar
    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
    GoSub QUERYMENU
    ' Remove the menu from the menu bar
    currMenuGroup.Menus.RemoveMenuFromMenuBar ("TestMenu")
    GoSub QUERYMENU
    Exit Sub
QUERYMENU:
    If newMenu.OnMenuBar Then
        MsgBox "The menu called " & newMenu.name & " is on the menu bar."
    Else
        MsgBox "The menu called " & newMenu.name & " is not on the menu bar."
    End If
    Return
(defun c:Example_OnMenuBar()
    ;; This example creates a new menu called TestMenu and inserts a menu item
    ;; into it. The menu is then displayed on the menu bar, and then
    ;; removed from the menu bar.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new menu
    (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
    ;; Add a menu item to the new menu
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
    ;; Display the menu on the menu bar
    (vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
    (if (= (vla-get-OnMenuBar newMenu) :vlax-true)
        (alert (strcat "The menu called " (vla-get-Name newMenu) " is on the menu bar."))
        (alert (strcat "The menu called " (vla-get-Name newMenu) " is not on the menu bar."))
    ;; Remove the menu from the menu bar
    (vla-RemoveMenuFromMenuBar (vla-get-Menus currMenuGroup) "TestMenu")
GMT+8, 2026-10-17 22:10
