Menus 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 853| 评论: 0|原作者: admin|来自: AutoCAD
Menus 属性 (ActiveX)
获取 PopupMenus 集合。
object.Menus
类型:MenuGroup
此属性应用于的对象。
只读:是的
类型:弹出菜单
声明为集合的用户指定的变量。PopupMenus
Sub Example_Menus()
    ' This example finds the names of all menus in the first menu group.
    Dim menuNames As String
    Dim menuCollection As AcadPopupMenus
    Dim menu As AcadPopupMenu
    Set menuCollection = ThisDrawing.Application.MenuGroups.Item(0).Menus
    menuNames = ""
    For Each menu In menuCollection
        menuNames = menuNames & menu.name & vbCrLf
    Next menu
    MsgBox menuNames
(defun c:Example_Menus()
    ;; This example finds the names of all menus in the first menu group.
    (setq menuCollection (vla-get-Menus (vla-Item (vla-get-MenuGroups acadObj) 0))
          menuNames "")
    (vlax-for menu menuCollection
        (setq menuNames (strcat menuNames (vla-get-Name menu) "\n"))
    (alert menuNames)
GMT+8, 2026-10-17 20:58
