Measurement 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 787| 评论: 0|原作者: admin|来自: AutoCAD
获取维度的度量值。
object.Measurement
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:是的
类型:双
对于线性尺寸,这是一个长度,对于角度尺寸,这是一个角度。
对于非角度尺寸,此属性将覆盖 DIMLUNIT 系统变量的值。
对于角度尺寸,此属性将覆盖 DIMAUNIT 系统变量的值。
Sub Example_Measurement()
    ' This example creates an aligned dimension in model space
    ' and returns the measurement of the dimension; in the case
    ' of a linear dimension, this measurement will be its length
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 9: point2(1) = 5: point2(2) = 0
    ' Read and display current measurement
    MsgBox "The current measurement of the new dimension is: " & dimObj.Measurement
(defun c:Example_Measurement()
    ;; This example creates an aligned dimension in model space
    ;; and returns the measurement of the dimension; in the case
    ;; of a linear dimension, this measurement will be its length
    ;; Define the dimension
          point2 (vlax-3d-point 9 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current measurement
    (alert (strcat "The current measurement of the new dimension is: " (rtos (vla-get-Measurement dimObj) 2)))
GMT+8, 2026-11-2 16:15
