MaxActiveViewports 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 652| 评论: 0|原作者: admin|来自: AutoCAD
指定活动视口的最大数量。
object.MaxActiveViewports
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:整数
活动视口的最大数量;2 <= MaxActiveViewports <= 48
非活动视口为空白,因此不会重新生成其内容。因此,您可以通过指定一个较低的值来提高性能。初始值为 48。
注意:此属性的值存储在 MAXACTVP 系统变量中。
Sub Example_MaxActiveViewports()
    ' MaxActiveViewports. It then changes the value, and finally
    Dim currMaxActiveViewports As Integer
    Dim newMaxActiveViewports As Integer
    ' Retrieve the current MaxActiveViewports value
    currMaxActiveViewports = ThisDrawing.preferences.MaxActiveViewports
    MsgBox "The current value for MaxActiveViewports is " & currMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
    ' Change the value for MaxActiveViewports
    newMaxActiveViewports = 20
    ThisDrawing.preferences.MaxActiveViewports = newMaxActiveViewports
    MsgBox "The new value for MaxActiveViewports is " & newMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
    ' Reset MaxActiveViewports to its original value
    ThisDrawing.preferences.MaxActiveViewports = currMaxActiveViewports
    MsgBox "The MaxActiveViewports value is reset to " & currMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
(defun c:Example_MaxActiveViewports()
    ;; MaxActiveViewports. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current MaxActiveViewports value
    (setq currMaxActiveViewports (vla-get-MaxActiveViewports preferences))
    (alert (strcat "The current value for MaxActiveViewports is " (itoa currMaxActiveViewports)))
    ;; Change the value for MaxActiveViewports
    (setq newMaxActiveViewports 20)
    (vla-put-MaxActiveViewports preferences newMaxActiveViewports)
    (alert (strcat "The new value for MaxActiveViewports is " (itoa newMaxActiveViewports)))
    ;; Reset MaxActiveViewports to its original value
    (vla-put-MaxActiveViewports preferences currMaxActiveViewports)
    (alert (strcat "The MaxActiveViewports value is reset to " (itoa currMaxActiveViewports)))
GMT+8, 2026-10-17 22:28
