MajorRadius 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 941| 评论: 0|原作者: admin|来自: AutoCAD
指定椭圆的长轴的长度。
object.MajorRadius
类型:椭圆
此属性应用于的对象。
只读:不
类型:双
椭圆的长轴长度。
椭圆的长轴称为长轴;较短的是短轴。
Sub Example_MajorRadius()
    ' This example creates an Ellipse in model space and displays
    ' both the Major radius and the Minor radius of the new Ellipse
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double, center(0 To 2) As Double
    Dim radRatio As Double
    ' Create an ellipse in model space
    center(0) = 5: center(1) = 5: center(2) = 0
    majAxis(0) = 10: majAxis(1) = 20: majAxis(2) = 0
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ' Display radius information
    MsgBox "The major radius of the new Ellipse is: " & ellObj.majorRadius & vbCrLf & _
           "The minor radius of the new Ellipse is: " & ellObj.minorRadius
(defun c:Example_MajorRadius()
    ;; This example creates an Ellipse in model space and displays
    ;; both the Major radius and the Minor radius of the new Ellipse
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    ;; Display radius information
    (alert (strcat "The major radius of the new Ellipse is: " (rtos (vla-get-majorRadius ellObj) 2)
                   "\nThe minor radius of the new Ellipse is: " (rtos (vla-get-minorRadius ellObj) 2)))
GMT+8, 2026-11-30 19:14
